    JohnSL FSR board and z probe setup
    • stephencundefined
      stephenc
      This question regarding z probing using JohnSL FSR board. That board has 3 FSR connection. My printer will have dual extruder with its own x and z axes. For setting bed mesh levelling, Do I need two of JohnSL board or 1 is sufficient?
      I'd like to use only 1 FSR board and use that same FSR to probe both head independently. Is this doable? If so then I think this would automatically took care of the offset between the two hotends in the event of changing nozzles
      Thanks,
      Stephen
      Stephen
      https://github.com/stephenci/ZideX
        On a standard IDEX machine with independent X carriages but a common Z axis, I think you could run G29 bed probing separately for each head, storing the resulting height maps using different filenames. Then in the tpost#.g tool change files, load the height map for the incoming tool.
        If you have a separate Z axis for each head, one option might be to use the FSRs to Z home each head independently, switching the Z axis to the appropriate motor driver using M584. After homing both, use M584 to assign both drivers to Z.
        Either way, only one FSR interface board needed.
        • stephencundefined
          stephenc
          thank you 42 I do have separate Z axis and got the duex5 as well
          I'm not sure what you mean by "use M584 to assign both drivers to Z."
          I was about to use
          M584 X0 Y1 Z2 U3 V4 E5:6 ; U for the other x axis and V for the other z axis and basically the two extruder motor will connect to Duex5
          Stephen
            The current firmware doesn't support remapping the Z axis in the way that it supports remapping X and Y, so you can't use V as a substitute Z axis. That's why you will need to use M584 to change the Z driver mapping if you want to perform G29 mesh bed probing separately for each head. If you are happy with both Z motors moving together most of the time, then Z2:4 can be the normal mapping in M584 and you can change it to Z2 or Z4 just when you want to probe the bed.
            • stephencundefined
              stephenc
              Will that be implemented in future firmware? I think it would continue to build upon the idea of U map to X and V map to Z
              Thanks,
              Stephen
              Stephen
