    Issues with CURA slicing for DUET2
    Using Duet Controllers
    • kareka
      kareka last edited by
      I ugraded my DUET2wifi firmware for v3.2.2 and the cura slicing is not start the cooling fan. It generates M106 S255 (for 100% speed) and this version requires M106 P0 S255. It is necessary to specify the configure port. Is there any way to configure CURA for this? Help is most welcome!
      • T3P3Tony
        T3P3Tony administrators @kareka last edited by
        @kareka set your tool up to have your part cooling fan specified as part of the tool and then the M106 S255 should work then that tool is selected:
        https://duet3d.dozuki.com/Wiki/M563
        e.g. (adapt this for your existing M563 command):
        M563 P0 D0 H1 F0
        www.duet3d.com
