    Heater Fault
    • PCNoobNeedsMajorHelp
      PCNoobNeedsMajorHelp last edited by
      I haven't used my printer in a while. The last time I used it everything worked great, so I'm not sure why I'm getting a fault. All my connections look good. Not sure where to go from here or how to fix it. Thanks in advance!
      jumpedwithbothfeet 1 Reply Last reply Reply Quote 0
      • jumpedwithbothfeet
        jumpedwithbothfeet @PCNoobNeedsMajorHelp last edited by
        @pcnoobneedsmajorhelp, power down your printer and disconnect your thermistor then check its resistance against the manufacturers specs then also check for shorts/breaks in the wiring 🙂
        Voron Trident based (4Z) - too much to list!
