    CAMWorks PostProcessor
    CNC
    • Sejl
      Sejl last edited by
      Any idea where can I find PostProcessor for Duet firmware 3+ for SolidWorks (CAMWorks)?
      I have tried using grbl postprocessor, but it has no G, M, T in front of every line, so it's pretty much unusable.
      Thanks in advance for any suggestion!
      Best regards
      Sejl mkrsjak 3DOeste 3 Replies Last reply Reply Quote 0
      • Sejl
        Sejl @Sejl last edited by
        @sejl
        Is there maybe some tool that can convert PostProcessor from Fusion360 to CamWorks? This could also be helpful.
        Thank you
        • mkrsjak
          mkrsjak @Sejl last edited by
          @sejl hello, did you find a solution for solidworks postprocess?
          • 3DOeste
            3DOeste @Sejl last edited by
            @Sejl you don’t need a special post processor, just use a fanuc one and remove the canned cycles. All the Gs and Ms in every line are no longer needed, it behaves as a normal industrial Cnc, once a command is sent, all the lines following are under that command, unless you change it again.
