    [3.4.0beta6] M956 causing soft reset
    Beta Firmware
    • ajdtreyd
      ajdtreyd last edited by ajdtreyd
      I get a system reset now every time I run M956.
      This was working fine on 3.3 using same macro and entering commands from console.
      The command from the macro is
      G1 X50 Y0 G4 S2 G1 X-50 Y0 F15000 M400 M956 P0 S1000 A0 F"{var.runTime}_PAR-Xneg"
      But I have tried the following from the console with the same result
      M956 P0 S1000 A0 F"test-123"
      M956 P0 S1000 A0
      M956 P0 S10 A0
      The following M122 was taken while running a macro just before crash:
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta6 (2021-11-06 11:37:41) running on Duet WiFi 1.02 or later
      Board ID: 08DGM-917NK-F23T0-6JKF0-3SD6S-TGBJD
      Used output buffers: 3 of 24 (24 max)
      Static ram: 23772
      Dynamic ram: 77400 of which 0 recycled
      Never used RAM 7908, free system stack 122 words
      Tasks: ACCEL(notifyWait,0.0%,350) NETWORK(ready,14.6%,228) HEAT(notifyWait,0.0%,326) Move(notifyWait,0.0%,305) MAIN(running,85.4%,442) IDLE(ready,0.0%,30), total 100.0%
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:05:29 ago, cause: software
      Last software reset at 2021-11-06 15:43, reason: HeatTaskStuck, GCodes spinning, available RAM 8116, slot 2
      Software reset code 0x4143 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x2001899c Task ACCE Freestk 350 ok
      Stack: 00434589 0045639a 21000000 00000001 200182d8 00000006 00000028 a5a5a5a5 a5a5a5a5 20004c08 00455eeb 40000000 200182d8 00000007 000003e8 00000007 00456163 200182d8 10000007 00000007 0000000a 2000118c 004559f1 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5
      Error status: 0x04
      Aux0 errors 0,0,0
      Step timer max interval 0
      MCU temperature: min 31.5, current 32.3, max 32.7
      Supply voltage: min 12.3, current 12.4, max 12.5, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/46/36, gc cycles 0
      Driver 0: pos 51839, standstill, SG min 0
      Driver 1: pos 61904, standstill, SG min 0
      Driver 2: pos 57130, standstill, SG min 0
      Driver 3: pos 0, standstill, SG min n/a
      Driver 4: pos 0, standstill, SG min n/a
      Driver 5: pos 0
      Driver 6: pos 0
      Driver 7: pos 0
      Driver 8: pos 0
      Driver 9: pos 0
      Driver 10: pos 0
      Driver 11: pos 0
      Date/time: 2021-11-06 15:49:25
      Slowest loop: 7.90ms; fastest: 0.15ms
      === Storage ===
      Free file entries: 9
      SD card longest read time 0.8ms, write time 0.0ms, max retries 0
      DMs created 83, segments created 6, maxWait 143612ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 15, completed 15, hiccups 48, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
      === AuxDDARing ===
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP is doing "G4 S2 " in state(s) 0 0, running macro
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty
      === Network ===
      Slowest loop: 200.00ms; fastest: 0.08ms
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is active
      Failed messages: pending 0, notready 0, noresp 1
      WiFi firmware version 1.26
      WiFi MAC address b4:e6:2d:52:f5:b7
      WiFi Vcc 3.36, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 25040
      WiFi IP address 192.168.0.22
      WiFi signal strength -41dBm, mode 802.11n, reconnections 0, sleep mode modem
      Clock register 00002002
      This one was from after the resulting reset:
      M122
      Used output buffers: 3 of 24 (20 max)
      Static ram: 23772
      Dynamic ram: 75252 of which 0 recycled
      Never used RAM 10200, free system stack 184 words
      Tasks: NETWORK(ready,13.7%,228) HEAT(notifyWait,0.0%,326) Move(notifyWait,0.0%,364) MAIN(running,85.0%,440) IDLE(ready,1.2%,30), total 100.0%
      Last reset 00:01:16 ago, cause: software
      Last software reset at 2021-11-06 15:49, reason: HeatTaskStuck, GCodes spinning, available RAM 7908, slot 0
      Stack: 00434589 0043458a 61000000 00000001 200182d8 00000006 00000028 a5a5a5a5 a5a5a5a5 20004c08 00455eeb 40000000 200182d8 00000007 000003e8 00000007 00456163 200182d8 10000007 00000007 0000000a 2000118c 004559f1 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5
      Error status: 0x00
      Aux0 errors 0,0,0
      MCU temperature: min 31.8, current 32.6, max 32.8
      Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/18/18, gc cycles 0
      Driver 0: pos 113137, standstill, SG min n/a
      Driver 1: pos 113137, standstill, SG min n/a
      Driver 2: pos 113137, standstill, SG min n/a
      Driver 5: pos 0
      Driver 6: pos 0
      Driver 7: pos 0
      Driver 8: pos 0
      Driver 9: pos 0
      Driver 10: pos 0
      Driver 11: pos 0
      Date/time: 2021-11-06 15:51:03
      Cache data hit count 2715428994
      Slowest loop: 8.38ms; fastest: 0.17ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 0.8ms, write time 1.1ms, max retries 0
      DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      === AuxDDARing ===
      Segments left: 0
      HTTP is idle in state(s) 0
      Code queue is empty
      === Network ===
      Slowest loop: 15.45ms; fastest: 0.00ms
      - WiFi -
      WiFi flash size 4194304, free heap 24960
      WiFi signal strength -40dBm, mode 802.11n, reconnections 0, sleep mode modem
      I'm getting no errors from my config.g:
      M98 P"0:/sys/config.g"
      HTTP is enabled on port 80
      FTP is disabled
      TELNET is disabled
      I get no errors configuring the accelerometer through macro or console:
      M955 P0 C"spi.cs1+spi.cs2" I20
      M955 P0
      Accelerometer 0 type LIS3DH with orientation 20 samples at 1344Hz with 10-bit resolution, SPI frequency 2000000
      I did a search for M956 causing reset but found only one post for one of the 3.3 pre-releases.
      Thanks in advance!
        dc42 administrators @ajdtreyd last edited by
        @ajdtreyd I suspect that the INT signal from the accelerometer to the Duet is not connected correctly.
        ajdtreyd 1 Reply Last reply Reply Quote 0
        • ajdtreyd
          ajdtreyd @dc42 last edited by
          All connections between the accelerometer and duet were mapped correctly when I checked this morning. However, after re-seating at both ends everything is working as expected. Perhaps one of the wires is intermittently breaking. I used a solid core Cat6 cable and should probably remake with silicon jacketed, braided wire given all the movement.
          I assumed that the issue was software because I had tested the accelerometer just before the update and the failure occurred just after. A good example of "correlation doesn't equal causation"!
          Thanks for the help and pointing out the obvious thing I should have checked!
