    Unsolved Advice for improving print quality
    • jrjones88
      jrjones88 last edited by
      I'm not really sure what I am doing wrong.
      After fixing a bad thermistor/hot end connection, I thought I was back on track getting decent print quality.
      I just changed nozzles from 0.4 to 0.6 mm on a print (layer height kept the same) and the quality was drastically worse.
      On the 0.4 mm nozzle prints I was getting some striations, which I thought was strange, but could live with it. With the 0.6 mm nozzle prints, it looks like layer shifting but everything physical with the printer is in order (belts are tensioned, I don't notice skipping, etc).
      The blobbing is me still needing to get retraction tuned properly, but would appreciate any advice.
      0.6mm Nozzle
      0.4mm nozzle, same object
      Printer base is a Seemecnc RostockMaxV2 (Delta)
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.0 or 1.01
      Board ID: 08DAM-999TL-MQ4S8-6J1FL-3SN6S-9QBRX
      Config here:
      ; generated by RepRapFirmware Configuration Tool v3.3.0 on Thu Aug 05 2021 19:10:57 GMT-0700 (Pacific Daylight Time)
      G90                                               ; send absolute coordinates...
      M83                                               ; ...but relative extruder moves
      M550 P"M-Automation"                              ; set printer name
      M665 R138.543 L290.8 B140 H592.5 X0.714 Y1.066 Z0.000     ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X-0.353 Y-0.422 Z0.775 A-0.48 B0.30          ; put your endstop adjustments here, or let auto calibration find them
      M552 S1                                           ; enable network
      M586 P0 S1                                        ; enable HTTP
      M586 P1 S0                                        ; disable FTP
      M586 P2 S0                                        ; disable Telnet
      M569 P0 S0                                        ; physical drive 0 goes backwards
      M569 P1 S1                                        ; physical drive 1 goes forwards
      M569 P2 S0                                        ; physical drive 2 goes backwards
      M569 P3 S1                                        ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                                  ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                           ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z80.00 E416.78859                  ; set steps per mm
      M566 X1000.00 Y1000.00 Z1000.00 E3000.00 P1         ; set maximum instantaneous speed changes (mm/min)
      M203 X15000.00 Y15000.00 Z15000.00 E3000.00       ; set maximum speeds (mm/min)
      M201 X8300.00 Y8300.00 Z8300.00 E10000.00       ; set accelerations (mm/s^2)
      M906 X1400 Y1400 Z1400 E1400 I30                  ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                           ; Set idle timeout
      M208 Z-0.2 S1                                     ; set minimum Z
      M574 X2 S1 P"xstop"                               ; configure active-high endstop for high end on X via pin xstop
      M574 Y2 S1 P"ystop"                               ; configure active-high endstop for high end on Y via pin ystop
      M574 Z2 S1 P"zstop"                               ; configure active-high endstop for high end on Z via pin zstop
      M558 P8 C"^zprobe.in" H2.5 F300:150 A015 S0.02 T15000           ; set Z probe type to switch and the dive height + speeds
      G31 P1000 X0 Y0 Z-0.04                             ; set Z probe trigger value, offset and trigger height
      M557 R120 S15                                     ; define mesh grid
      M308 S0 P"duex.e4temp" Y"thermistor" T95205 B3285 ; configure sensor 0 as thermistor on pin duex.e4temp
      M950 H0 C"bedheat" T0                             ; create chamber heater output on bedheat and map it to sensor 0
      M307 H0 A19.0 C18.4 D1.6 S1.00 V12.7 B0           ; disable bang-bang mode for the chamber heater and set PWM limit
      M141 H0                                           ; map chamber to heater 0
      M143 H0 S105                                      ; set temperature limit for heater 0 to 105C
      M308 S1 P"e0temp" Y"thermistor" T108341 B4527     ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                              ; create nozzle heater output on e0heat and map it to sensor 1
      M307 B0 R2.201 C212.1 D6.73 S1.00 V12.7			  ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                      ; set temperature limit for heater 1 to 280C
      M308 S2 P"e1temp" Y"thermistor" T108341 B4527     ; configure sensor 2 as thermistor on pin e1temp
      M950 H2 C"e1heat" T2                              ; create bed heater output on e1heat and map it to sensor 2
      M307 H2 A190.3 C949.5 D1.2 S1.00 V12.8 B0         ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H2                                           ; map heated bed to heater 2
      M143 H2 S125                                      ; set temperature limit for heater 2 to 125C
      M308 S3 P"bedtemp" Y"thermistor"  A"Chamber Temp"  T103972 B10191 C4.825776e-7 R4700                     ; set thermistor + ADC parameters for chamber thermistor
      M950 F0 C"fan0" Q50000                            ; create fan 0 on pin fan0 and set its frequency
      M106 P0 C"CPU Fan" S0.25 H0 T30                   ; set fan 0 name and value. Thermostatic control is turned on
      M950 F1 C"fan1" Q0                                ; create fan 1 on pin fan1 and set its frequency
      M106 P1 C"Hot End" S1 H1 T45                      ; set fan 1 name and value. Thermostatic control is turned on
      M950 F2 C"fan2" Q500                              ; create fan 2 on pin fan2 and set its frequency
      M106 P2 C"Chamber Heater" S0.25 H1 T35            ; set fan 2 name and value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                                  ; define tool 0
      G10 P0 X0 Y0 Z0                                   ; set tool 0 axis offsets
      G10 P0 R0 S0                                      ; set initial tool 0 active and standby temperatures to 0C
      ; Custom settings
      ;CPU Temp compensation
      M912 P0 S-2.4
      ;Driver Temp Flag
      M305 P101 S"Drivers"
      ;Retraction
      M207 S2.0 R0.10 F6000 T4500 Z0
      M572 D0 S0
      M501                                              ; Load saved parameters from non-volatile memory
      T0                                                ; Select first tool
      Let me know if it is useful to have the gcode files, as they are ~12 mb in size, so too large to upload directly to the forum.
      percar 1 Reply Last reply Reply Quote 0
      • percar
        percar @jrjones88 last edited by
        @jrjones88
        There are a couple of items that can be causing this
        1. Check to insure that the extruder and hot end are not moving or loose. If it is loose then may get something that looks like your print
        2. Even though you are not hearing any clicking on the extruder the filament may not be feeding smoothly. Is this a bowden type extruser or direct Drive?
          If it is a bowden extruder try squirting some light oil in the bowden extruder to help eleviate some of the friction.
          Also clean out the nozzle as sometimes there are some small chunks in the nozzle that block the filament from extruding smoothly
          Check the actual filament drive as I have had issues where there was a string that was wedging against the filament and causing inconsistant extrusion
        3. The extruder is too cold. When going up in nozzle size you may have to increase the temperature for the highter volume. Try 10 or 15 degrees higher and see if it helps
