Solved 24v Fans on Duet 3 Mini?
I realised too late that fans should be 12v on my Duet 3 mini. Is there a way to allow the board to run 24v fans??
Yes, as long as Vin is 24V that's not a problem. They might already be set to 24V (Vin).
I assume you mean the Duet 3 Mini 5+ board version 1.0 (ish)?
I run two fans on 24V and two other on 12V.
@gixxerfast Brilliant!! I didn't notice the jumpers!!
Phaedrux
Phaedrux
