    Drivers over temp, but sensors read 0
    Duet Web Control
    144
    • tomasro
      tomasro last edited by
      I experienced a weird error last night where the drivers skipped steps and then stopped, reporting they were over temp. I have a sensor mapped to the driver temperature and it was reading 0.
      I shut down the machine for the night and came back in the morning and it was fine, but I am clueless as to what to do about this. It is the second time it's happened and I have active cooling to the backside of both my Duet Wifi and Duex5 boards.
      Specs:
      Duet Wifi 1.01 & Duex5 0.10
      Quad Z motors on drivers 5, 6, 7 and 8
      80mm fan active above 30 degrees
      m122 @1AM
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.0 or 1.01
      Board ID: 08DAM-999TL-MQ4S8-6JKDD-3SD6S-KP8HY
      Used output buffers: 3 of 24 (11 max)
      Static ram: 23876
      Dynamic ram: 75272 of which 12 recycled
      Never used RAM 15256, free system stack 184 words
      Tasks: NETWORK(ready,13.9%,236) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,364) MAIN(running,85.1%,441) IDLE(ready,1.0%,29), total 100.0%
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:01:37 ago, cause: software
      Last software reset at 2021-11-06 00:59, reason: User, GCodes spinning, available RAM 12048, slot 2
      Error status: 0x00
      Step timer max interval 0
      MCU temperature: min 21.2, current 24.7, max 24.9
      Supply voltage: min 24.5, current 24.6, max 24.9, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 0, standstill, SG min/max not available
      Driver 1: position 0, standstill, SG min/max not available
      Driver 2: position 0, standstill, SG min/max not available
      Driver 5: position 0
      Driver 6: position 0
      Driver 7: position 0
      Driver 8: position 0
      Driver 9: position 0
      Driver 10: position 0
      Driver 11: position 0
      Date/time: 2021-11-06 01:00:52
      Cache data hit count 3495336090
      Slowest loop: 8.42ms; fastest: 0.17ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 1.2ms, write time 0.0ms, max retries 0
      === MainDDARing ===
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Filament sensors ===
      Extruder 0 sensor: no filament
      === Network ===
      Slowest loop: 15.48ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is active
      WiFi firmware version 1.26
      WiFi MAC address ---
      WiFi Vcc 3.38, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 22040
      WiFi IP address 192.168.1.200
      WiFi signal strength -46dBm, mode 802.11n, reconnections 0, sleep mode modem
      Clock register 00002002
      Socket states: 0 4 0 0 0 0 0 0
      m122@ 1PM
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.0 or 1.01 + DueX5
      Used output buffers: 3 of 24 (24 max)
      Static ram: 23876
      Dynamic ram: 75816 of which 320 recycled
      Never used RAM 11548, free system stack 124 words
      Tasks: NETWORK(ready,14.2%,236) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,304) DUEX(notifyWait,0.0%,24) MAIN(running,85.7%,441) IDLE(ready,0.0%,29), total 100.0%
      Owned mutexes:
      Last reset 04:22:11 ago, cause: power up
      Error status: 0x00
      MCU temperature: min 24.2, current 24.4, max 25.1
      Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/12/8, gc cycles 0
      Driver 0: position 400, ok, SG min/max 70/142
      Driver 1: position -400, ok, SG min/max 60/137
      Driver 2: position 4040, standstill, SG min/max not available
      Driver 5: position 0, standstill, SG min/max 8/1023
      Driver 6: position 0, standstill, SG min/max 33/1023
      Driver 7: position 0, standstill, SG min/max 63/1023
      Driver 8: position 0, standstill, SG min/max 18/1023
      Driver 9: position 0, standstill, SG min/max not available
      Date/time: 2021-11-06 13:33:04
      Slowest loop: 8.06ms; fastest: 0.17ms
      === Storage ===
      Free file entries: 9
      SD card longest read time 0.7ms, write time 0.0ms, max retries 0
      DMs created 83, maxWait 15691834ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 14, completed moves 13, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by HTTP
      HTTP is idle in state(s) 2 15, running macro
      Extruder 0 sensor: ok
      === DueX ===
      Read count 4, 8.54 reads/min
      === Network ===
      Slowest loop: 203.74ms; fastest: 0.08ms
      Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
      - WiFi -
      Failed messages: pending 0, notready 0, noresp 1
      WiFi flash size 4194304, free heap 23752
      Socket states: 4 0 0 0 0 0 0 0
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.4 on Fri Oct 22 2021 23:28:40 GMT-0700 (Pacific Daylight Time)
      G90                                                    ; send absolute coordinates...
      M83                                                    ; ...but relative extruder moves
      M550 P"R2D Cube"                                       ; set printer name
      M669 K1                                                ; select CoreXY mode
      M912 P0 S-8.2											;calibrate MCU temperature
      M552 S1                                                ; enable network
      M586 P0 S1                                             ; enable HTTP
      M586 P1 S0                                             ; disable FTP
      M586 P2 S0                                             ; disable Telnet
      M569 P0 S0                                             ; physical drive 0 goes backwards
      M569 P1 S0                                             ; physical drive 1 goes backwards
      M569 P3 S1                                             ; physical drive 3 goes forwards
      M569 P5 S0
      M569 P6 S0
      M569 P7 S0
      M569 P8 S0
      M584 X0 Y1 Z5:6:7:8 E3                                       ; set drive mapping
      M671 X-40:515:-40:515 Y37:37:430:430 S5 ; leadscrews at left front, right front, left rear, right rear
      M350 X16 Y16 Z16 E16 I1                                ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z808.00 E402.00                      ; set steps per mm
      M566 X900.00 Y900.00 Z100.00 E120.00                    ; set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z6000 E1200.00                ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z250 E250.00                    ; set accelerations (mm/s^2)
      M906 X900 Y900 Z800 E800 I1                            ; set motor currents (mA) and motor idle factor in per cent
      M84 S10                                                ; Set idle timeout
      M208 X0:455 Y0:405 Z0:420
      M591 P2 C"!duex.e2stop" S1   D0 			       ; filament monitor connected to E0 endstop
      M574 X1 S1 P"!duex.e3stop"                                   ; configure switch-type (e.g. microswitch) endstop for low end on X via pin !xstop
      M574 Y1 S1 P"!duex.e4stop"                                   ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin !ystop
      M574 Z1 S2                                             ; configure Z-probe endstop for low end on Z
      M950 S0 C"duex.pwm1"                                  ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H10 F600 T10000                   ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X35 Y35 Z1.7                                   ; set Z probe trigger value, offset and trigger height
      M557 X72:490 Y35:440 S100                              ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B3950         ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                                  ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B0 R0.221 C451.3 D2.62 S1.00             ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                ; map heated bed to heater 0
      M143 H0 S120                                           ; set temperature limit for heater 0 to 120C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                                   ; create nozzle heater output on e0heat and map it to sensor 1
      ;M307 H1 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
      M307 H1 B0 R2.107 C262.7:238.2 D6.31 S1.00 V24.6
      M143 H1 S280                                           ; set temperature limit for heater 1 to 280C
      M950 F0 C"fan0" Q500                                   ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                         ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                                   ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1.0 H1 T45                                     ; set fan 1 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                                       ; define tool 0
      G10 P0 X0 Y0 Z0                                        ; set tool 0 axis offsets
      G10 P0 R0 S0                                           ; set initial tool 0 active and standby temperatures to 0C
      ;Temp Sensor trigger
      M308 S2 Y"drivers" A"DRIVERS"  ; configure sensor 2 as temperature warning and overheat flags on the TMC2660 on Duet
      M308 S3 Y"mcu-temp" A"MCU" ; configure sensor 3 as on-chip MCU temperature sensor
      M950 F2 C"fan2" Q100 ; create fan 2 on pin fan2 and set its frequency
      ;M106 P2 H2:3 L0.15 X1 B0.3 T30:70 ; set fan 2 value
      M106 P2 H2:3 S1 T30
        dc42 administrators @tomasro last edited by
        Was the overheating driver on the Duet or on the DueX5?
        @tomasro said in Drivers over temp, but sensors read 0:
        That configures temperature monitoring for the drivers on the Duet, but not the drivers on the DueX. To monitor drivers on the DueX, create an additional temperature sensor with type name "drivers-duex".
        tomasro 1 Reply Last reply Reply Quote 0
        • tomasro
          tomasro @dc42 last edited by
          @dc42 The console reported drivers 1 and 2 were over temp. Also, the board was misreading the X and Y axis to be homed, when the printhead was away from the home position
          cosmowave 1 Reply Last reply Reply Quote 0
          • cosmowave
            cosmowave @tomasro last edited by
            @tomasro An axis can be homed without touching the endstop!
            homed means, that the axis was homed in the past...
            Mankati FSXT+, DeltaTowerV2, CBot3D
            • tomasro
              tomasro @cosmowave last edited by
              @cosmowave I must not have been clear: The end stop monitor showed that the x and y endstops were triggered, and yet the carriage was in the middle of the bed (nowhere near the endstops)
              Also, the heater temperature went up to 2000C according to the thermister. It was a straight line up on the chart. And the filament sensor triggered, even though there was filament loaded
              Something VERY weird is going on here
              cosmowave engikeneer 2 Replies Last reply Reply Quote 0
              • cosmowave
                @tomasro Is the endstop triggered all the time? Or can you "untrigger" it when you press the endstop by hand?
                • tomasro
                  @cosmowave No. It's not that the endstop gets inverted. It's like the board is gets glitched.
                  Would anyone recommend heatsinks on the back of the board?
                  • cosmowave
                    @tomasro What shows the corresponding LED on the board? Does it light up with pressing/releasing endstop?
                    Normally active cooling should be enough...
                    • engikeneer
                      engikeneer @tomasro last edited by
                      @tomasro 2000C on your thermistors indicates a short. I might be wrong, but wouldn't your endstops being triggered also imply a short, and same for the filament sensor?
                      The driver over temp warning might also be a red herring - I've seen that happen when I've shut off the 24V on my printer (whilst still keeping an external 5V supply so the processor and DWC stay up). I think the sudden voltage drop triggers something in the drivers/comms. So it could be a voltage/short issue causing it...
                      I'd start checking some things in the wiring. Maybe try unplugging everything from the board and see what DWC reports? Also try (carefully!) measuring the 3.3v and 5v rails to check if they're okay and that the grounds are not floating etc.
                      Looking at your config, it seems these issues are across both the Duet and Duex?
                      Beyond those ideas, you might need @dc42 's help...
                      i3 clone with a bunch of mods
