    M561 the same as G29 S2?
    Using Duet Controllers
    • resamundefined
      resam
      Is M561 the same as G29 S2?
      The doc pages read similar, though not identical, and don't mention each other.
      https://duet3d.dozuki.com/Wiki/G29
      https://duet3d.dozuki.com/Wiki/M561
      • Gixxerfastundefined
        Gixxerfast
        "M561 Clear height map (same as G29 S2)"
        Bottom of this page:
        https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
        Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
        Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
        Ender 3 Pro with BTT SKR-2 + RRF
          I don't think they started out as identical, but when mesh compensation replaced the old defined point compensation they took on the same role: clearing bed height adjustments.
          resamundefined 1 Reply Last reply Reply Quote 0
          • resamundefined
            resam @Phaedrux
            Thanks everyone!
            @phaedrux would be great if you could update both docs pages with a simple cross-link and a sentence that explains that they are equal.
            • resamundefined resam has marked this topic as solved
