    Duet 3 mini 5+ IDEX build AKA Viper 3D
    My Duet controlled machine
    • make_shake99undefined
      make_shake99
      Hi All,
      Thought I'd share my custom IDEX machine I finally got working. Its 500mm, 500mm, 440mm build volume. I'm using NF Zone Volcano hotends with orbiter extruders. It started out as a duet 2 wifi with expansion boards but changed it over to make use of the toolboards which made my wiring much easier and clean. There are a few things to tweak and test but over all seems pretty good so far.
      Milicigundefined 1 Reply Last reply Reply Quote 1
      • Milicigundefined
        Milicig @make_shake99
        @make_shake99 I'm trying to build the ratrig v-cast idex. Any chance you could share your config so i can maybe try to tweak it to work with my printer. By the way that's a great printer. BIG!
        make_shake99undefined 1 Reply Last reply Reply Quote 0
          make_shake99 @Milicig
          @milicig
          I have it posted in this thread https://forum.duet3d.com/topic/25907/homing-issue-on-idex?_=1636755743309
          Just note the two comments that need adjusted in home files.
          Milicigundefined 1 Reply Last reply Reply Quote 0
          • Milicigundefined
            @make_shake99 sweet thank you. I added the changes the comments say. And those changes are just to homeall.g and homes.g where i add TO P0 in the first line where i add a line before the G91 comand like. And then add add another line with T-1 at the end but before the commented out lines with G91. I attached the picture to see if i did it right because right now I'm trying to do 3 things at once and I'm just getting overloaded where i can't do one thing right let alone 3. 😂!!20211115_002252.jpg
              @milicig The t-1 would only need to go into your end of print g code, which is a slicer setting such as cura.
