    [3.3] Tool heater reports "standby" while actually being "off"
    Beta Firmware
    • seeul8erundefined
      seeul8er
      RepRap Object model reports tool to be in state standby while it is "off" in DWC.
      When powered on the tool state is correctly reported to be "off". Switching the tool heater to active followed by standby and off via DWC, causes the object model to return state "standby" while DWC indicates the correct state "off".
      as reported by "/rr_model?flags=d99fn" under "tools" -> "state"
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.3 (2021-06-15)
      Duet WiFi Server Version: 1.26
      Duet Web Control 3.3.0
      • fcwiltundefined
        fcwilt @seeul8er
        @seeul8er
        It may be that tool state and heater state are not the same.
        I would assume that the DWC is showing the heater state.
        seeul8erundefined 1 Reply Last reply Reply Quote 1
        • seeul8erundefined
          seeul8er @fcwilt
          @fcwilt I checked and you are right. The heater state is consistent. The tool state can then be ignored. I see no benefit for now
