InternalServerException in InstallPlugin:
Firmware installation
958
  • undefined
    joeko
    hallo,
    on firmware 3.3 i cant install a plugin. also the service is not present or can be found. the duet is running on an sbc (odroid)
    i always get the message
    InternalServerException in InstallPlugin: Win32Exception in InstallPlugin: No such file or directory
    undefined 1 Reply Last reply 16 Nov 2021, 16:03 Reply Quote 0
    • undefined
      which plugin are you trying to install and how are you trying to install it?
      Are all of the duet services and files up to date on the SBC?
      undefined 1 Reply Last reply 16 Nov 2021, 16:04 Reply Quote 0
      • undefined
        jay_s_uk @joeko
        @joeko if upgrading from an earlier image or installing on your own, you need the plugin service installed.
        details are here https://github.com/Duet3D/DuetSoftwareFramework/wiki/Changelog-DSF-3.x#version-330
        undefined 1 Reply Last reply 16 Nov 2021, 16:07 Reply Quote 1
        • undefined
          joeko @Phaedrux
          @phaedrux said in InternalServerException in InstallPlugin::
          i tried it with BtnCmd-DWC and with objectcancel plugin. i tried it with upload and start. after the question to install i get this message. i have installed the firmware one hoer ago (version 3.3.01?) all files are up to date
          • undefined
            joeko @jay_s_uk
            @jay_s_uk said in InternalServerException in InstallPlugin::
            yes i did this again and finaly i get this message
            InvalidOperationException in InstallPlugin: Cannot perform command because the plugin service is not started
            undefined 1 Reply Last reply 16 Nov 2021, 16:08 Reply Quote 0
            • undefined
              jay_s_uk @joeko
              @joeko is the plugin service running?
              • undefined
                joeko
                duetpluginservice.service - Duet Plugin Service
                Loaded: loaded (/usr/lib/systemd/system/duetpluginservice.service; enabled; vendor preset: enabled)
                Active: active (running) since Tue 2021-11-16 17:07:04 CET; 4min 49s ago
                Main PID: 2293 (DuetPluginServi)
                Tasks: 8 (limit: 3844)
                Memory: 19.5M
                CGroup: /system.slice/duetpluginservice.service
                └─2293 /opt/dsf/bin/DuetPluginService
                Nov 16 17:07:04 Vcore systemd[1]: Started Duet Plugin Service.
                Nov 16 17:07:05 Vcore DuetPluginService[2293]: Duet Plugin Service v3.3.0
                Nov 16 17:07:05 Vcore DuetPluginService[2293]: Written by Christian Hammacher for Duet3D
                Nov 16 17:07:05 Vcore DuetPluginService[2293]: Licensed under the terms of the GNU Public License Version 3
                Nov 16 17:07:05 Vcore DuetPluginService[2293]: [info] DuetPluginService.Program: Settings loaded
                Nov 16 17:07:06 Vcore DuetPluginService[2293]: [info] DuetPluginService.Program: Connection established
                Nov 16 17:10:06 Vcore DuetPluginService[2293]: [warn] Plugin ObjectCancel: Deleting previous installation directory
                Nov 16 17:10:06 Vcore DuetPluginService[2293]: [info] Plugin ObjectCancel: Installing files
                Nov 16 17:10:06 Vcore DuetPluginService[2293]: [info] Plugin ObjectCancel: File installation complete
                and
                ● duetpluginservice-root.service - Duet Plugin Service (root)
                Loaded: loaded (/usr/lib/systemd/system/duetpluginservice-root.service; enabled; vendor preset: enabled)
                Active: active (running) since Tue 2021-11-16 17:07:04 CET; 6min ago
                Main PID: 2289 (DuetPluginServi)
                Tasks: 9 (limit: 3844)
                Memory: 15.2M
                CGroup: /system.slice/duetpluginservice-root.service
                └─2289 /opt/dsf/bin/DuetPluginService
                Nov 16 17:10:06 Vcore DuetPluginService[2289]: System.ComponentModel.Win32Exception (2): No such file or directory
                Nov 16 17:10:06 Vcore DuetPluginService[2289]: at System.Diagnostics.Process.ForkAndExecProcess(String filename, String[] argv, String[] envp, String cwd,
                Nov 16 17:10:06 Vcore DuetPluginService[2289]: at System.Diagnostics.Process.StartCore(ProcessStartInfo startInfo)
                Nov 16 17:10:06 Vcore DuetPluginService[2289]: at System.Diagnostics.Process.Start()
                Nov 16 17:10:06 Vcore DuetPluginService[2289]: at System.Diagnostics.Process.Start(ProcessStartInfo startInfo)
                Nov 16 17:10:06 Vcore DuetPluginService[2289]: at System.Diagnostics.Process.Start(String fileName, String arguments)
                Nov 16 17:10:06 Vcore DuetPluginService[2289]: at DuetPluginService.Permissions.AppArmor.InstallProfile(Plugin plugin) in /home/christian/Duet3D/DuetSoftw
                Nov 16 17:10:06 Vcore DuetPluginService[2289]: at DuetPluginService.Commands.InstallPlugin.Execute() in /home/christian/Duet3D/DuetSoftwareFramework/src/D
                Nov 16 17:10:06 Vcore DuetPluginService[2289]: at DuetAPI.Commands.Command.Invoke() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetAPI/Commands/B
                Nov 16 17:10:06 Vcore DuetPluginService[2289]: at DuetPluginService.IPC.Service.Run() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetPluginServic
                undefined 1 Reply Last reply 16 Nov 2021, 16:17 Reply Quote 0
                • undefined
                  chrishamm administrators @joeko
                  @joeko It looks like the root plugin service cannot reload the apparmor profile which is why you get that internalserverexception. Please follow exactly the steps from the upgrade notes to make sure apparmor is installed and enabled.
                  Duet software engineer
                  undefined 4 Replies Last reply 16 Nov 2021, 17:29 Reply Quote 0
                  • undefined
                    joeko @chrishamm
                    @chrishamm said in InternalServerException in InstallPlugin::
                    i did it moretimes
                    • undefined
                      joeko @chrishamm
                      i flashed the debian buster again and make all new.
                      i followed the howto from here exactly
                      after this
                      sudo apt install apparmor
                      Enable AppArmor support on boot: sudo bash -c 'echo " lsm=apparmor" >> /boot/cmdline.txt'
                      Enable new plugin services: sudo systemctl enable duetpluginservice && sudo systemctl enable duetpluginservice-root
                      Failed to enable unit: Unit file duetpluginservice.service does not exist.
                      i dont know what is wrong....
                      • undefined
                        joeko @chrishamm
                        this does not install the plugin service
                        apt-get install duetpluginservice install it but the root serice doesnt run
                        • undefined
                          joeko
                          i have now install ubuntu minimal.
                          the service is now active but when i try to install a plugin over upload&install i get a new message
                          InternalServerException in InstallPlugin: UnauthorizedAccessException in InstallPlugin: Access to the path '/opt/dsf/sd/www/BtnCmd.b3e030d8.css' is denied.
                          • undefined
                            joeko
                            ok, 2 days now for nothing
                            i have tried now to install the latest beta like in the guide.
                            after sudo apt update && sudo apt upgrade i can see the updates but they wont be install without an errormessage
                            Aktualisierung für 8 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, u m sie anzuzeigen.
                            Paketlisten werden gelesen... Fertig
                            Abhängigkeitsbaum wird aufgebaut.
                            Statusinformationen werden eingelesen.... Fertig
                            Paketaktualisierung (Upgrade) wird berechnet... Fertig
                            Die folgenden Pakete sind zurückgehalten worden:
                            duetcontrolserver duetpluginservice duetruntime duettools duetwebcontrol
                            duetwebserver reprapfirmware
                            0 aktualisiert, 0 neu installiert, 0 zu entfernen und 7 nicht aktualisiert.
                            joern@Vcore:~$ apt list --upgradable
                            Listing... Done
                            duetcontrolserver/unstable 3.4-b5 arm64 [upgradable from: 3.3.0]
                            duetpluginservice/unstable 3.4-b5 arm64 [upgradable from: 3.3.0]
                            duetruntime/unstable 3.4-b5 arm64 [upgradable from: 3.3.0]
                            duetsoftwareframework/unstable 3.4-b5 arm64 [upgradable from: 3.3.0]
                            duettools/unstable 3.4-b5 arm64 [upgradable from: 3.3.0]
                            duetwebcontrol/unstable 3.4-b5 all [upgradable from: 3.3.0]
                            duetwebserver/unstable 3.4-b5 arm64 [upgradable from: 3.3.0]
                            reprapfirmware/unstable 3.4-b6-1 all [upgradable from: 3.3.0-1]
                            is there a secrete to install the beta ? i do exactly what the guide tell me...
                            • undefined
                              What version is currently installed when you try to upgrade?
                              undefined 1 Reply Last reply 18 Nov 2021, 06:53 Reply Quote 0
                              • undefined
                                joeko @Phaedrux
                                M122
                                RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v1.01 or later (SBC mode)
                                Board ID: 08DJM-956BA-NA3TJ-6JKD8-3S46Q-1A8GS
                                Used output buffers: 1 of 40 (17 max)
                                Static ram: 150904
                                Dynamic ram: 61684 of which 580 recycled
                                Never used RAM 141024, free system stack 200 words
                                Tasks: SBC(ready,5.1%,328) HEAT(delaying,0.0%,325) Move(notifyWait,0.0%,302) CanReceiv(notifyWait,0.0%,799) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,7.1%,93) MAIN(running,87.7%,922) IDLE(ready,0.1%,29), total 100.0%
                                Owned mutexes: HTTP(MAIN)
                                Last reset 00:02:37 ago, cause: power up
                                Last software reset at 2021-11-17 19:01, reason: User, GCodes spinning, available RAM 141024, slot 0
                                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
                                Error status: 0x00
                                Aux0 errors 0,0,0
                                Step timer max interval 129
                                MCU temperature: min 12.0, current 24.8, max 24.9
                                Supply voltage: min 24.0, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                                12V rail voltage: min 12.2, current 12.2, max 12.2, under voltage events: 0
                                Driver 0: position 0, standstill, reads 28255, writes 18 timeouts 0, SG min/max 0/0
                                Driver 1: position 0, standstill, reads 28255, writes 18 timeouts 0, SG min/max 0/0
                                Driver 2: position 0, standstill, reads 28255, writes 18 timeouts 0, SG min/max 0/0
                                Driver 3: position 0, standstill, reads 28255, writes 18 timeouts 0, SG min/max 0/0
                                Driver 4: position 0, standstill, reads 28255, writes 18 timeouts 0, SG min/max 0/0
                                Driver 5: position 0, standstill, reads 28262, writes 11 timeouts 0, SG min/max 0/0
                                Date/time: 2021-11-18 07:48:24
                                Slowest loop: 1.10ms; fastest: 0.03ms
                                === Storage ===
                                Free file entries: 10
                                === MainDDARing ===
                                === AuxDDARing ===
                                Segments left: 0
                                Movement lock held by null
                                Telnet* is idle in state(s) 0
                                File is idle in state(s) 0
                                USB is idle in state(s) 0
                                Aux is idle in state(s) 0
                                Queue is idle in state(s) 0
                                LCD is idle in state(s) 0
                                SBC is idle in state(s) 0
                                Daemon is idle in state(s) 0
                                Aux2 is idle in state(s) 0
                                Code queue is empty.
                                === CAN ===
                                Messages queued 1349, received 1646, lost 0, longest wait 2ms for reply type 6049, peak Tx sync delay 179, free buffers 49 (min 48), ts 790/789/0
                                Tx timeouts 0,0,0,0,0,0
                                === SBC interface ===
                                State: 4, failed transfers: 0, checksum errors: 0
                                Last transfer: 1ms ago
                                RX/TX seq numbers: 5478/5478
                                SPI underruns 0, overruns 0
                                Disconnects: 0, timeouts: 0, IAP RAM available 0x2c810
                                Buffer RX/TX: 0/0-0
                                === Duet Control Server ===
                                Duet Control Server v3.3.0
                                Code buffer space: 4096
                                Configured SPI speed: 8000000Hz
                                Full transfers per second: 0.18, max wait times: 11.9ms/0.0ms
                                Codes per second: 0.01
                                Maximum length of RX/TX data transfers: 2896/932
                                as i setup up the sbc it looks like rrf 3.3.0.1 will install but now is 3.3. also i got the message that user dsf doesnt exist but now user dsf is present.
                                • undefined
                                  joeko @chrishamm
                                  @chrishamm
                                  i got for testing an raspberry 3 from a friend.
                                  on a raspberry i can install or setup the sbc like in the guide (i did the new setup and not the duetpi image)
                                  on the raspberry i dont have to modify the /opt/dsf/conf/config.json file because the conf.json is preset while the setup. while the setup i can see that the firmwar is installing. with an other sbc i get the error that the sbc is not found until i modify the config.json and i dont see firmware installing.
                                  it is possible, while the sbc setup or installation, to modify the config.json or use the standard config.json ? this should be easy to do or not ?
                                  this would make it much easier to setup an non raspbery sbc.
                                  beside this, it was possible to install and start the managment plugin but not install others without the errormessage and both duetplugin services was running
                                  undefined 1 Reply Last reply 19 Nov 2021, 13:57 Reply Quote 0
                                  • undefined
                                    @joeko You can delete /opt/dsf/conf/config.json and then restart DCS or the Pi to revert to the defaults. DCS creates the config file automatically if it does not exist.
                                    undefined 1 Reply Last reply 19 Nov 2021, 15:09 Reply Quote 0
                                    • undefined
                                      joeko @chrishamm
                                      hmm, you have misunderstood me.
                                      i am talking about a new setup for the sbc like written in the guide
                                      after
                                      wget -q https://pkg.duet3d.com/duet3d.gpg
                                      wget -q https://pkg.duet3d.com/duet3d.list
                                      sudo mv duet3d.gpg /etc/apt/trusted.gpg.d/
                                      sudo mv duet3d.list /etc/apt/sources.list.d/duet3d.list
                                      sudo chown root:root /etc/apt/trusted.gpg.d/duet3d.gpg
                                      sudo chown root:root /etc/apt/sources.list.d/duet3d.list
                                      i have to
                                      sudo apt-get install apt-transport-https
                                      sudo apt-get update
                                      sudo apt-get install duetsoftwareframework
                                      the /opt/dsf/conf/config.json will create with
                                      this config.json has to modify with an other sbc than raspberry and the result is an error because the sbc is not found. if it would be possible to modify the config.json in this step
                                      it would be possible to make it easy to setup the sbc and should be easy to make it enable.
                                      also, is there a way to install the beta firmware ?
                                      sudo apt-get update
                                      sudo apt-get upgrade
                                      doesnt do it
                                      undefined 1 Reply Last reply 19 Nov 2021, 18:43 Reply Quote 0
                                      • undefined
                                        Phaedrux Moderator @joeko
                                        @joeko said in InternalServerException in InstallPlugin::
                                        First you must add the unstable branch repository
                                        https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Software_Installation
                                        undefined 1 Reply Last reply 19 Nov 2021, 19:55 Reply Quote 0
                                        • undefined
                                          joeko @Phaedrux
                                          yes i know and i did but after apt-get update and upgrade i get the message that updates hold back without any reason. (i wrote it in post 259113 from 17.11
                                          without sbc i can use M997 for update but in sbc mode ?
                                          8 out of 23
