    Can 2 versions of DWC coexist?
    Duet Web Control
    • CarlosRundefined
      CarlosR
      Hi all,
      Is it possible to mantain two versions of DWC coexisting?
      The idea is to use the original DWC as an advanced GUI (for expert users), and also create a modified version that is simpler and prettier (for final users).
      The plan is to serve each version in a different port, but my fear is if the data model will be shared correctly, if it will produce delays somehow, or if it will be incompatibilities.
      DWC is very complex, and it is easier to remove GUI elements and change appearence from the original than adapt the original to what we want.
      Thank you.
      PCRundefined 1 Reply Last reply Reply Quote 0
      • PCRundefined
        PCR @CarlosR
        @carlosr YES look at this. https://github.com/gtjoseph/DueUI/wiki
        CarlosRundefined 1 Reply Last reply Reply Quote 1
        • CarlosRundefined
          CarlosR @PCR
          @pcr Thank you! I will
