    Cura slicer filament usage in multi extrusion
    Using Duet Controllers
    • MathVundefined
      MathV
      The gcodes generated by Cura (4.11.0)with multi extruders only show the filament usage of the last extruder in DWC 3.3.0 (SBC mode).
      I am attaching the gcodes I used to test it (I shortened the files so they are not too heavy).
      In the first one, both extruders are used, and only the filament usage of the last extruder (T1) is reported, and 1 extruder only appears in the OM.
      TEST_FILAMENT_USAGE_1.gcode
      In the second one, both extruders are activated, but one only (T0) is used. The OM report an unvalid type code 15 (the gcode shows a filament use of 0m).
      TEST_FILAMENT_USAGE_2.gcode
      Does anybody knows if it comes from the 4.11.0 Cura (the parser is looking for "ilament" so it should work) or from a bug in DWC 3.3.0?
      Thanks for you feedbacks.
      T3P3Tonyundefined chrishammundefined 2 Replies Last reply Reply Quote 0
      • T3P3Tonyundefined
        T3P3Tony administrators @MathV
        @mathv this is one for @chrishamm to look at, thanks for providing the gcodes to reproduce it with.
        www.duet3d.com
        • chrishammundefined
          chrishamm administrators @MathV
          @mathv Thanks for reporting this, I am going to fix it in the next version.
          Duet software engineer
