    Can't Connect to my Duet 3 Mini Wifi V1.1
    Firmware installation
    • Wolfgang.Kleinundefined
      Wolfgang.Klein
      Hello, after a few hours of testing i will ask for support, i will configure my board Duet 3 Mini Wifi V1.1. I was installing the Windows USB Drivers, check my USB cable, the status led tell me a CRC Firmware problem. My Windows Laptops, i was testing with 2, They can't find the port. Now i want to erase the system, but i can't find the erase pin. What must i do to get connection to the board. many many thanks for support. Regards Wolfgang
      Stephen6309undefined 1 Reply Last reply Reply Quote 0
      • Stephen6309undefined
        Stephen6309 @Wolfgang.Klein
        @wolfgang-klein https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Duet_3_Mini_5_WiFi_Ethernet
        Wolfgang.Kleinundefined 1 Reply Last reply Reply Quote 1
          Wolfgang.Klein @Stephen6309
          @stephen6309 hello thank you very much i will try it and let you know. Reards wolfgang
          Wolfgang.Kleinundefined 1 Reply Last reply Reply Quote 0
            Wolfgang.Klein @Wolfgang.Klein
            @wolfgang-klein Thank you for the help it is working now. Regards Wolfgang
            • T3P3Tonyundefined T3P3Tony marked this topic as a question
            • T3P3Tonyundefined T3P3Tony has marked this topic as solved
