    Wishlist - Add Simulate to the right click menu
    Duet Web Control wishlist
    • DADIY
      DADIY last edited by
      Would be really useful if the simulate command M37 P"filename.g" was added as an option when you right-click a file in DWC.
      thanks
      DA
      • Dougal1957
        Dougal1957 last edited by
        I just send M37 s1 to enable sim mode then print the file from the dwc then send M37 S0 to disable it afterwards (or when you have done with simulation should you want to do it on several files) and then M37 to get the results.
        I have set those comands in the drop down in the Gcode box at the top of DWC so it makes it easy
        • mhackney
          mhackney last edited by
          +1 on this, I was just going to add the request myself. Dougal1957's is a nice interim solution, thanks!
          My 3D Printing blog: http://www.sublimelayers.com
          Coming this summer: "3D Printing Strategies - the art of perfecting your designs and prints"
          • darookee
            darookee last edited by
            It's already in 1.19.3 of the WebUI! 😄
            • Dougal1957
              It is indeed
                @darookee:
                …which is available at https://github.com/chrishamm/DuetWebControl/blob/master/DuetWebControl-1.19.3.zip (FOLLOW that link and then press Download), and also in the Release/Duetxxx/Edge folders of my own github repo alongside RRF 1.20beta1.
                You can also sort GCode files by date in that release.
                Thanks, Chris!
                • mhackney
                  Excellent!
