Configurator seems to not generate the stated files.
@frankv If you reload the configtool on the last page, it loses all the entered value. So go back to the start, click on the last radio item, and then reload your config.json before you generate the ZIP bundle. I'll have a look at this issue anyway.
@chrishamm reuploaded it. I exposed my wifi credentials. It's my first config so there could be stuff in what is not good. Maybe the fact i offset the probe to minus 22mm.
@chrishamm It worked! Mostly.
"File list missing" in red showed up, then it seemed to proceed normally.All the new *.g files appeared in DWC and immediately fans came on for the first time ever. Yay!
Then it stated "Please wait while updates are being installed".
It's been over 10 minutes. I'm a bit afraid to RESET for fear of maybe bricking the board if it REALLY is updating it's firmware.Thoughts?
@kcress After 25 minutes I rebooted the HC's.
Then it left me muddling about since it changed IP addresses. Had to comb the router tables to find Waldo. But it was there and now I get motion too. A little screwed up X,Y move reversed directions but I should have that sorted after some sleep.
Thanks all for the help.
chrishamm; A big thanks for jumping on that configurator issue so fast. Big kudos man! -
