    Configurator seems to not generate the stated files.
    Config Tool
    703
    • FrankVundefined
      FrankV @kcress
      @kcress @chrishamm you need to rename them in Winrar because when they unarchive you get extention .g_ instead of .g
      kcressundefined 1 Reply Last reply Reply Quote 0
      • kcressundefined
        kcress @FrankV
        @frankv Yikes! Thanks for that tip. 7zip generates the .g_ too.
        • chrishammundefined
          chrishamm administrators @kcress
          @kcress @FrankV Now fixed in v3.3.7, please reload the configtool using Ctrl+Shift+R and it will produce correct archives again.
          Duet software engineer
          kcressundefined FrankVundefined 2 Replies Last reply Reply Quote 0
          • kcressundefined
            kcress @chrishamm
            @chrishamm Indeed that works correctly with windoz AND 7zip. The .g files are there without "_".
            Thanks. Do you think this was related to the file upload problem? I'm thinking it is. I'll go out to the shop and try it. 3:50am. LOL
            • FrankVundefined
              FrankV @chrishamm
              @chrishamm still got issues did refresh.
                @kcress Yes, I think so. I changed my dev setup from Linux to Windows the other day so the filenames in v3.3.6 had an extra line break character (CR) at the end, which wasn't there before and barely visible (doh!).
                FrankVundefined 1 Reply Last reply Reply Quote 0
                  chrishamm administrators @FrankV
                  @frankv Please share your config.json file again.
                  • FrankVundefined
                    FrankV @chrishamm
                    This post is deleted!
                      @frankv If you reload the configtool on the last page, it loses all the entered value. So go back to the start, click on the last radio item, and then reload your config.json before you generate the ZIP bundle. I'll have a look at this issue anyway.
                      • FrankVundefined
                        FrankV @chrishamm
                        @chrishamm reuploaded it. I exposed my wifi credentials. It's my first config so there could be stuff in what is not good. Maybe the fact i offset the probe to minus 22mm.
                        config.json
                        • kcressundefined
                          kcress @chrishamm
                          @chrishamm It worked! Mostly.
                          "File list missing" in red showed up, then it seemed to proceed normally.
                          All the new *.g files appeared in DWC and immediately fans came on for the first time ever. Yay!
                          Then it stated "Please wait while updates are being installed".
                          It's been over 10 minutes. I'm a bit afraid to RESET for fear of maybe bricking the board if it REALLY is updating it's firmware.
                          Thoughts?
                          • kcressundefined
                            kcress @kcress
                            @kcress After 25 minutes I rebooted the HC's.
                            Then it left me muddling about since it changed IP addresses. Had to comb the router tables to find Waldo. But it was there and now I get motion too. A little screwed up X,Y move reversed directions but I should have that sorted after some sleep.
                            Thanks all for the help.
                            chrishamm; A big thanks for jumping on that configurator issue so fast. Big kudos man!
                            • Phaedruxundefined Phaedrux has marked this topic as solved
