    edited revert firmware page in teh docs
    DSF Development
    • achrnundefined
      achrn
      I had cause to roll back my firmware from 3.4-b6 to 3.3.0, and the instructions at https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3?revisionid=HEAD#Section_Software_Installation failed badly at the step 7:
      pi@delta:~ $ sudo apt install -y --allow-downgrades duetsoftwareframework/stable duetcontrolserver/stable duetwebserver/stable duettools/stable duetruntime/stable duetwebcontrol/stable
      Reading package lists... Done
      Building dependency tree
      Reading state information... Done
      Selected version '3.3.0' (stable [armhf]) for 'duetsoftwareframework'
      Selected version '3.3.0' (stable [armhf]) for 'duetpluginservice' because of 'duetsoftwareframework'
      Selected version '3.3.0' (stable [armhf]) for 'duetcontrolserver'
      Selected version '3.3.0' (stable [armhf]) for 'duetwebserver'
      Selected version '3.3.0' (stable [armhf]) for 'duettools'
      Selected version '3.3.0' (stable [armhf]) for 'duetruntime'
      Selected version '3.3.0' (stable [all]) for 'duetwebcontrol'
      You might want to run 'apt --fix-broken install' to correct these.
      The following packages have unmet dependencies:
       duetpluginservice : Depends: duetcontrolserver (= 3.4-b6) but 3.3.0 is to be installed
      E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
      pi@delta:~ $ sudo apt --fix-broken install
      Correcting dependencies... Done
      The following package was automatically installed and is no longer required:
        duetruntime
      Use 'sudo apt autoremove' to remove it.
      The following packages will be REMOVED:
        duetcontrolserver duetpluginservice duetsd duetsoftwareframework duettools duetwebcontrol duetwebserver
        reprapfirmware
      0 upgraded, 0 newly installed, 8 to remove and 0 not upgraded.
      After this operation, 0 B of additional disk space will be used.
      Do you want to continue? [Y/n]
      (Reading database ... 88329 files and directories currently installed.)
      Removing duetpluginservice (3.4-b6) ...
      Removing duetwebserver (3.4-b6) ...
      Removing reprapfirmware (3.3.0-1) ...
      Removing duetsd (1.1.0) ...
      Removing duetwebcontrol (3.4-b6) ...
      dpkg: warning: while removing duetwebcontrol, directory '/opt/dsf/dwc/js' not empty so not removed
      Removing duetcontrolserver (3.4-b6) ...
      To delete "gpio" group run as root: groupdel gpio
      Removing duetsoftwareframework (3.4-b6) ...
      To delete the "dsf" user run as root: userdel --force dsf
      Removing duettools (3.4-b6) ...
      I then tried some flailing around:
      pi@delta:~ $ sudo apt install duetsoftwareframework
      Some packages could not be installed. This may mean that you have
      requested an impossible situation or if you are using the unstable
      distribution that some required packages have not yet been created
      or been moved out of Incoming.
      The following information may help to resolve the situation:
       duetsoftwareframework : Depends: duetcontrolserver (= 3.3.0) but it is not going to be installed
                               Depends: duettools (= 3.3.0) but it is not going to be installed
                               Depends: duetwebserver (= 3.3.0) but it is not going to be installed
                               Depends: reprapfirmware (>= 3.3.0-1) but it is not going to be installed
                               Depends: reprapfirmware (<= 3.3.0-999) but it is not going to be installed
                               Recommends: duetpluginservice (= 3.3.0) but it is not going to be installed
      E: Unable to correct problems, you have held broken packages.
      pi@delta:~ $ sudo apt install duetwebcontrol
       duetwebcontrol : Depends: duetsoftwareframework (>= 3.2.0) but it is not going to be installed
      It seems to me the first step of the instructions was wrong to say "only if reverting to v3.2", and you need that step also if reverting from 3.4-b6 to 3.3. So I've deleted the statement on dozuki.
      If I re-revert to 3.4-b6 and then re-re-revert following the instructions but do remove duetpluginservice as step 1, it goes OK.
      However, I'm somewhat ignorant here - copying out instructions without much knowledge about what I'm doing - so someone who understands it might want to review what I've done to the documentation.
      jay_s_ukundefined chrishammundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @achrn
        @achrn this should downgrade you back to 3.3.0
        sudo apt install \
            duetsoftwareframework=3.3.0 \
            duetcontrolserver=3.3.0 \
            duetruntime=3.3.0 \
            duetsd=1.1.0 \
            duettools=3.3.0 \
            duetwebcontrol=3.3.0 \
            duetwebserver=3.3.0 \
            reprapfirmware=3.3.0-1 \
            --allow-downgrades```
        • chrishammundefined
          chrishamm administrators @achrn
          @achrn Thanks for pointing it out, I've updated the docs again and removed the first step in favour of downgrading DPS via the last step along with the other packages.
          Duet software engineer
          achrnundefined 1 Reply Last reply Reply Quote 0
          • achrnundefined
            achrn @chrishamm
            @chrishamm OK.
            It occurs to me that I might have added DPS manually, in which case the previous would not have affected someone that had not. However, presumably apt will take care of it if it's not installed.
