    tool to reverse gcode into STL or other editable format
    Off Topic
    • c310undefined
      c310
      Hello! I need to reverse engineer three parts because initial files are lost 😞
      all i have now is gcode....
      can you advise tool or method to convert it to something editable?
      thanks!
      theruttmeisterundefined Sindariusundefined 2 Replies Last reply Reply Quote 0
      • theruttmeisterundefined
        theruttmeister @c310
        @c310 there's a blender plugin that visualizes gcode into a solid model. Or you could try to write some code to convert the gcode back into an STL, but that's a bit complicated. Needing to correctly offset things would be a challenge.
        Or print the parts and get some calipers.
        Isolate, substitute, verify.
        • CNCModellerundefined
          CNCModeller
          Or print the gcode and 3d scan it...
          Polar Duet3 Mini + 1HCL
          https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
          Wanhao D4S: Duet2
          https://forum.duet3d.com/post/296755
          K40 Laser, Duet2
          https://forum.duet3d.com/post/312082
          Wanhao D5S
          https://www.youtube.com/CNCModellerUK
          • Sindariusundefined
            Sindarius @c310
            @c310 you can try the Voxelizer 2 Experimental slicer and see if they still have the gcode to stl conversion available. It voxelized the gcode and builds an stl out if it. Depending on the accuracy may need this may not be optimal.
            https://voxelizer.com/download
            • Mr Yodundefined
              Mr Yod
              I have a similar need, but for a sketch: it's a laser engraving gcode about which I lost the corresponding drawing (and the toolpath is a mess).
