Bad PT100 Daughterboard
I purchased a PT100 daughterboard from a reseller just over a week ago and had issues when installing it today on a Mini 5+. I already have one on my 6HC board so I set it up the same way. Attached a known good PT100 sensor and got nothing. Tried the second connection and got nothing there either. After verifying I had not made any connection or configuration errors, I removed it from the Mini 5+ and figured I'd try it with the 6HC board since it already has one working in it. I attached the PT100 sensor from the Mini 5A+ to the daughterboard in the 6HC and that worked. I swapped out the working daughterboard in the 6HC with the new one and again got nothing on either channel. I put the original back in the 6HC and no problems. Has to be a bad daughterboard and can get a warranty exchange, correct?
@lelynch I agree, it sounds like a bad daughter board to me. Please email warranty@duet3d.com.
