    tool changer calibration
    • gold-junge91undefined
      gold-junge91
      Hi boys im new her and i hope i get help i have a lot of research done but get nothing right working.
      My case:
      Duet 3 Mainboard 6HC 4x Tool board,
      2x Z endstops stops on Z Max
      mesh probe on my X Carriage for mesh probe.
      and i want to make a Nozzle probe:
      its a microswitch mounted on my Z (bed ) carriage close to my heated bed, i don't get the values on the Z
      what i have to do if i want a fixed Probe for nozzles offsets in Z on my bed
        I'm afraid I don't understand what you're asking.
        • 2500ccmundefined
          2500ccm
          Hey i understand him. I think you want a switch for the different length of your nozzles. I am searching for the same thing.
          https://forum.duet3d.com/topic/18106/tool-length-sensor-tls-for-e-g-tool-changing
          This is a good way to start. He use parallel the bltouch. So it is a second z endstop.
          • rjenkinsgbundefined
            rjenkinsgb
            I have a tool changing system on one of my machines.
            In that, I reference and level without a tool loaded, then have Z offset for each tool in the tool configs.
            Once set, they should never need changing, or at least until you replace a nozzle.
            To calibrate them, I just set the Z at zero in the tool initially, pick it up and measure the height the nozzle touches the bed, then put that value in the tool Z offset; done.
            Check it prints OK and adjust the offset fractionally if it's not perfect.
            Accurately calibrating the X & Y offsets to be able to do multi-material prints is much harder - I've not done that so far, I'm still doing other tweaks on the machine.
            Robert J.
            Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
