    JohnSL wiring question
    • stephenc
      stephenc last edited by
      This might be obvious but I was looking at the wiring guide quoted here the JohnSL board "Vcc, Output and Ground pins to 3V3, STP and GND respectively on the E0 endstop connector" but the FSR board connection is "Sig, +/-, -+" so I'm a bit confused where to connect. Can we update to guide to reference the same name used in JohnSL?
      Thanks,
      Stephen
      Stephen
      https://github.com/stephenci/ZideX
      • KeeganB
        KeeganB last edited by
        On the John SL board, the center pin is ground, the pin closest to the corner of the board is 3v3, and the pin closest to the sensitivity jumpers is Signal.
        Does that help?
        Artemis
        Rostock Max v2
        Orion
        • stephenc
          thank you I think that should be added to the documentation 🙂
          Stephen
          • stephenc
            Actually just read this http://trains.socha.com/2014/05/auto-adjust-fsr-end-stop-detector.html
            he mentioned the two "+/-" doesn't matter which one goes to V or ground.
            Stephen
            • Khayrisill
              Khayrisill last edited by
              Sorry guys, still unclear for me… I agree with @KeeganB when he say
              But I don't understand what sense do we speak for the E0 Endstop to the Duet… Vcc, Output and Ground.
              thanks
              • KeeganB
                @Khayrisill:
                thanks
                https://duet3d.com/wiki/Duet_WiFi_and_Ethernet_wiring_diagrams
                if you look at your board in the same orientation as that diagram, the pins (from left to right) are Signal, Power, Ground
                Artemis
                Rostock Max v2
                Orion
                • Khayrisill
                  This is exactly what I was looking for
