    Paused message doesnt self clear
    Duet Web Control
    457
    • ukwebbundefined
      ukwebb
      Not sure if this is a bug, or a bug that has been fixed but I've noticed that ... if my printer pauses due to the filament sensor, and I then resume the printer via the PanelDue, next time I lview the web interface, the message saying "your print is paused - Extruder 0 reports too little movement" appears, even though in the background you can clearly see the x,y positions moving happily away.
      clicking dismiss on the message has zero effect, other than clearing the message - its just concerning when you first view it as you think the printer has paused again.
      I'm on stable release 3.3.0 with a Duet3Mini5+ in standalone mode
      Any thoughts?
        What firmware version is your PanelDue?
        ukwebbundefined 1 Reply Last reply Reply Quote 0
        • Phaedruxundefined Phaedrux moved this topic from Duet Web Control
        • ukwebbundefined
          ukwebb @Phaedrux
          @phaedrux
          v3.2.11
            Can you try updating it?
            • ukwebbundefined
              ukwebb @Phaedrux
              @phaedrux updated to 3.4.0
              same thing 😞
              • ukwebbundefined
                ukwebb
                I'm happy to be proved wrong, but why would it be due to paneldue ? the print does resume and the browser shows that - and the paused message goes from paneldue . Its only on the Duet Web interface that still shows it.
                  Thanks for clarifying.
                  • Phaedruxundefined Phaedrux moved this topic from PanelDue
                  • ukwebbundefined
                    ukwebb @Phaedrux
                    @phaedrux any thoughts on the issue
                    • does anyone else have the issue?
                      @chrishamm might have an idea
                      • chrishammundefined
                        chrishamm administrators @Phaedrux
                        @phaedrux I think message boxes of any kind can be dismissed by sending M292 and DWC sends that when you press OK (whereas M292 P1 is sent when Cancel is pressed). So it's probably PanelDue that acts differently, perhaps it only hides the messagebox and does not send any code so it remains active on DWC.
                        To work-around this problem, you can add M292 to resume.g.
                        Duet software engineer
                        • ukwebbundefined
                          ukwebb @chrishamm
                          @chrishamm that does appear ( on the first and only try ) to have fixed it - thankyou
