    Yet another BLtouch problem
    Firmware installation
    2.2k
    • Macgyverundefined
      Macgyver
      Think I must be going blind here just cannot see the problem, Running Version 3 firmware
      I have a BLTouch plugged in, I'm using the pins on the expansion card plugin from a Duet 2. I have a brown and red set respectively on gnd and +5. Yellow is set on HEATER7, White and black are set on Zprobe_in and Gnd respectively
      When I boot it up I get deploy and retract 2X but cannot M401/M402 the probe. Deploy and retract macros do not work either. No blue light on the probe. Can someone have a look at my config and see what I'm missing here? I know it's gonna be something obvious.....
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Mar 02 2021 18:05:15 GMT-0500 (Eastern Standard Time)
      M550 P"Duet600" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S1 ; CP physical drive 0 goes forwards
      M569 P1 S0 ; physical drive 1 goes forwards
      M569 P2 S0 ; physical drive 2 goes forwards
      M569 P4 S1 ; physical drive 4 goes forwards
      M584 X0 Y1 Z2 E3:4 ; set drive mapping
      M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
      M92 X106.70 Y106.25 Z800.00 E424.00:424.00 ; CP set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X10000.00 Y10000.00 Z300.00 E1200.00:1200.00 ; CP set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
      M906 X2000 Y2000 Z2000 E1000:1000 I40 ; CP set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X600 Y600 Z600 S0 ; set axis maxima
      M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop
      M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
      ;M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !zstop
      M574 Z1 S1 P"!Z_PROBE_IN" ; configure active-high endstop for low end on Z via pin !zstop
      ;M591 P1 C"e0stop" S1 D0 ; CP filament monitor connected to E0 endstop
      ;M591 P1 C"e1stop" S1 D1 ; CP filament monitor connected to E1 endstop
      M950 S0 C"exp.heater7" ; Create GPIO port S0
      M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to 9 BL Touch and the dive height + speeds
      M558 P0
      G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X15:585 Y15:585 S20 ; define mesh grid
      M307 H0 R0.159 C663.482:663.482 D11.40 S1.00 V24.2 B0 ; CP disable bang-bang mode for the bed heater and set PWM limit CP and pid
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C0.0000000706 ; CP configure sensor 1 as thermistor on pin e0temp
      M307 H1 R1.494 C256.1 D6.91 S1.00 V24.2 ; CP disable bang-bang mode for heater and set PWM limit
      ;M308 S2 P"e1temp" Y"thermistor" T100000 B4725 C0.0000000706 ; CP configure sensor 2 as thermistor on pin e1temp
      ;M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
      ;M307 H2 R3.431 C159.3 D7.55 S1.00 V24.1 ; CP disable bang-bang mode for heater and set PWM limit
      ;M143 H2 S280 ; set temperature limit for heater 2 to 280C
      M950 F0 C"fan0" ; create fan 0 on pin fan0 and set its frequency
      M950 F1 C"fan1" ; create fan 1 on pin fan1 and set its frequency
      M950 F2 C"fan2" ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S1 H2 T45 ; set fan 2 value. Thermostatic control is turned on
      M563 P0 S"Left Extruder" D0 H1 F-1 ; define tool 0
      M563 P1 S"Right Extruder" D1 H2 F0 ; define tool 1
      G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
      G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
      M401
      M402
      Deploy macro
      ; deployprobe.g
      ; called to deploy a physical Z probe
      M280 P0 S10
      retract Macro
      ; retractprobe.g
      ; called to retract a physical Z probe
      M280 P0 S90
      Gixxerfastundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • Gixxerfastundefined
        Gixxerfast @Macgyver
        @macgyver If you have the expansion breakout board. From the documentation:
        "If you have a Expansion Breakout Board, it's !exp.heater6 or !exp.heater7 ('!' inverts the output, and is needed)."
        Example:
        M950 S0 C"!exp.heater6" ; Duet 2 WiFi/Ethernet + BoB
        Could this help?
        Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
        Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
        Ender 3 Pro with BTT SKR-2 + RRF
        • Macgyverundefined
          Macgyver
          No, I don't have the duex
          I am using the connector where the duex would plug into. I am using a couple of DuPont connectors to use the 3 connections I need within it.
          • Macgyverundefined
            Macgyver
            I did just try it with the !, still does not function. Updated line below
            M950 S0 C"!exp.heater7" ; Create GPIO port S0
            Gixxerfastundefined 1 Reply Last reply Reply Quote 0
              @macgyver Isn't this lonely one a bit strange:
              M558 P0
              I would remove that as I guess it redefines K0 as there's no zprobe?
              • Macgyverundefined
                Macgyver
                @Gixxerfast
                I agree, Cannot remember at this point why I had it there.
                I have commented it out and restarted it. Still no blue light and no response from M401/402 or the macros
                I have it plugged into Heater7 and I have the pin called
                is this correct or should I refer to it as PWM5 I believe?
                  @macgyver Try to remove the negation if you haven't already
                  EDIT: Oh, you did already.
                  If that doesn't work we'll have to wait for someone who knows about the Duet 2:s
                  Btw, what kind of BLTouch do you have. Can you trust the wire colours. Mine is a genuine BLTouch but sold by Creality and the wire colours are completely different.
                  Also, blue light. I have no blue light on my bltouch only the red glow (I haven't seen any anyway).
                    Phaedrux Moderator @Macgyver
                    @macgyver said in Yet another BLtouch problem:
                    Remove this line entirely.
                    M558 P0
                    Remove this line as well.
                    Can you show a photo of the wiring?
                    Have you tested the wiring for continuity with a multimeter?
                    Can you verify that your deploy and retract macros are located in the /sys folder?
                    • Macgyverundefined
                      Macgyver
                      hi @Phaedrux
                      I have removed completely both lines you mentioned.
                      I am attaching a photo of the wiring. Currently, this is basically a retro install to a D600 so it's a bit of a beast to move around. To eliminate a wiring issue through the drag chain I have used an official BLtouch and the short wiring that comes with it to jack straight into the board. I did a sanity check and verified the wiring of the short harness and it's good.
                      I looked in my System menu on my DWC and the deploy and retract macros are in the same folder physical folder as the config.g.
                      I would have to yank the SD card to absolutely verify if you would like it.
                      Just noticed something odd though. I have a deployprobe and retractprobe macro, as well as a deployprobe.g and a retractprobe.g. Im gonna pull the card and verify locations.
                      Thanks for giving me a hand with this.
                        @macgyver But can you run the M280 P0 S10 and/or M280 P0 S90 directly? If not, maybe you could try with heater3 ?
                          Can you also send M122 and M98 P"config.g" and post the results?
                          Macgyverundefined 1 Reply Last reply Reply Quote 0
                          • Macgyverundefined
                            Macgyver @Phaedrux
                            the Deploy and retract macros were in the macros folder. I have made a copy of them and now they are located in both macro and sys folders.
                            Rebooted the printer and still nothing.
                            If I go to the next step and type; M280 P0 S10 which is out of the deploy macro then still nothing happens. That being said it stands to reason that something in my config.g is incorrect?
                            M950 S0 C"!exp.heater5"; assign GPIO port 0 to heater5 on expansion connector, servo mode
                            • this seems correct as I am connected to the Heater 5 output on the expansion connector.
                            • this one is telling the Duet where the input of the trigger is going, which technically should be used until after the probe gets deployed. But if not configured correctly will prevent the blue light from coming on, which is true in my case. No blue light at all. Only red
                            • Macgyverundefined
                              Macgyver
                              other output requested is as follows
                              12/17/2021, 5:41:15 PM M122
                              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
                              Board ID: 0JD0M-9K662-MGPSS-6JKD2-3SJ6J-1ASYW
                              Used output buffers: 3 of 24 (21 max)
                              Static ram: 23876
                              Dynamic ram: 75152 of which 12 recycled
                              Never used RAM 12520, free system stack 170 words
                              Tasks: NETWORK(ready,13.5%,233) HEAT(delaying,0.0%,314) Move(notifyWait,0.1%,329) MAIN(running,86.3%,403) IDLE(ready,0.1%,29), total 100.0%
                              Owned mutexes: WiFi(NETWORK)
                              Last reset 00:14:02 ago, cause: power up
                              Last software reset at 2021-12-14 08:54, reason: HardFault invState, GCodes spinning, available RAM 15168, slot 2
                              Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x00400003 BFAR 0xe000ed38 SP 0x2001ff60 Task MAIN Freestk 31241 ok
                              Stack: 20011a00 0000f76e 00000002 00000000 00000f79 00409be9 00000000 200f000f 00000000 20004c8c 0000c0f7 00000000 00000001 0040cac3 00000000 00000000 0000c0f7 0045acef 00000000 20005cd8 00000001 40080000 00030d41 00000000 00000001 00000407 20004c8c
                              Error status: 0x00
                              Step timer max interval 0
                              MCU temperature: min 14.6, current 25.3, max 25.5
                              Supply voltage: min 24.1, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                              Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/4/4, gc cycles 0
                              Driver 0: position 0, standstill, SG min/max not available
                              Driver 1: position 0, standstill, SG min/max not available
                              Driver 2: position 0, standstill, SG min/max not available
                              Driver 5: position 0
                              Driver 6: position 0
                              Driver 7: position 0
                              Driver 8: position 0
                              Driver 9: position 0
                              Driver 10: position 0
                              Driver 11: position 0
                              Date/time: 2021-12-17 17:41:14
                              Slowest loop: 5.15ms; fastest: 0.17ms
                              === Storage ===
                              Free file entries: 10
                              SD card longest read time 0.6ms, write time 0.0ms, max retries 0
                              === MainDDARing ===
                              === AuxDDARing ===
                              Segments left: 0
                              Movement lock held by null
                              HTTP is idle in state(s) 0
                              Telnet is idle in state(s) 0
                              File is idle in state(s) 0
                              USB is idle in state(s) 0
                              Aux is idle in state(s) 0
                              Trigger is idle in state(s) 0
                              Queue is idle in state(s) 0
                              LCD is idle in state(s) 0
                              Daemon is idle in state(s) 0
                              Code queue is empty.
                              === Network ===
                              Slowest loop: 73.61ms; fastest: 0.00ms
                              HTTP sessions: 1 of 8
                              • WiFi -
                                Network state is active
                                WiFi firmware version 1.26
                                WiFi MAC address 40:f5:20:0d:a9:ae
                                WiFi Vcc 3.31, reset reason Turned on by main processor
                                WiFi flash size 4194304, free heap 21488
                                WiFi IP address 192.168.66.46
                                WiFi signal strength -62dBm, mode 802.11n, reconnections 0, sleep mode modem
                                Clock register 00002002
                                12/17/2021, 5:40:55 PM M280 P0 S90
                                12/17/2021, 5:40:46 PM M280 P0 S10
                              • Macgyverundefined
                                Macgyver
                                @phaedrux said in Yet another BLtouch problem:
                                M98 P"config.g"
                                12/17/2021, 5:43:26 PM M98 P"config.g"
                                HTTP is enabled on port 80
                                FTP is disabled
                                TELNET is disabled
                                Error: bad grid definition: Too many grid points; suggest increase spacing to 28.5mm
                                Error: in file macro line 73 column 33: M563: expected number after 'F'
                                Error: Tool 0 not found
                                Interesting, does this mean it's not seeing the probe at all? Guess kinda makes sense with no blue light...
                                  I think you should double check that with the wiring diagram.
                                  https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams
                                  • Macgyverundefined
                                    Macgyver
                                    interesting development
                                    I have updated the grid spacing to 28.5 as suggested in the last output.
                                    I have removed the F switch on the M563 on line 73.
                                    Now the error message has changed substantially
                                    M98 P"config.g"
                                    FTP is disabled
                                    TELNET is disabled
                                    Error: Pin name needed for switch-type endstop on Z axis
                                    Pretty sure we are getting close to this.
                                    • Macgyverundefined
                                      Macgyver
                                      So I just did the following change, I know that @Phaedrux suggested that I remove the line but I'm trying to understand where this error is being generated from
                                      I removed Line 1
                                      M574 Z1 S1
                                      and replaced it with line 2
                                      Now I am not getting any error at all
                                      M98 P"config.g"
                                      FTP is disabled
                                      TELNET is disabled
                                      I am still getting a solid red light on the BLtouch but no blue at all. My understanding is the blue light is your confirmation the "sig" or yellow wire is functional on the board? that being said if I am correct it's not seeing the "rdy" on the heater5 pin on the EXP connector.
                                      I did double-check the wiring on the EXP and I was off by a pin so that is now confirmed to be in the correct location.
                                        Ok, so now does the deploy and retract work when sending M401 and M402?
                                          This is fine, but if you have no actua endstop connected to the zstop pins you'll end up with more problems if you ever tried to actually home the Z axis with an endstop movement command. (G1 H1 Z)
                                          • Macgyverundefined
                                            Macgyver
                                            I've gone the next step, I have a new Duet 2 board, just sitting on my desk, I have moved the firmware over to it and flashed it at 3.3.
                                            Its a little easier to move pins around and troubleshoot with the board on my desk instead of at the bottom of a big ol printer.
                                            I have replicated the current install of the board in the printer and still getting the same symptoms.
                                            I have put an M401 and M402 at the end of my config.g so if the pin deploys and stows 3 times on startup it should be working fine. I have used a new BLtouch, New short harness for the BLtouch.
                                            The only thing I have hooked to it is the BLtouch and an i7 screen. I also wanted to eliminate the possibility that the board is bad in the printer and I think this is the best way to do it.
                                            To give updates, I have tried heater 5,3, and 8. None of them change any of the symptoms. M401 and M402 do not work.
