    How much power?
    • David J
      David J last edited by
      I'm trying to reorganise my power supply requirements following an imminent change to the heated bed (I'm going to a 230v bed).
      All I need to know is what current the Duet board, hot-end, 4 stepper motors a few fans and LEDs will require. If someone can tell me that, or give me a reasonable estimate, I can add a percentage for good luck and work out the wattage I'll need.
      Thanks in advance,
      David
      • deckingman
        deckingman last edited by
        This should have all the info you need to work it out https://duet3d.com/wiki/Choosing_the_power_supply
        • David J
          Rats! I knew I'd seen the information somewhere!
          If all else fails, RTFM (Read The *** Manual) 🙂
          Thanks.
          • DjDemonD
            DjDemonD last edited by
            150w is plenty 120 might be enough
            www.precisionpiezo.co.uk
            • David J
              I've done the sums and it looks like a good-quality 150W PSU will cover all of my needs for a long while. A MeanWell PSU doesn't have a fan at that size, which is a bonus (I'm trying to reduce noise as well as improve efficiency).
              Thanks again to all.
              • deckingman
                No worries. If you haven't noticed already, using Duet electronics, the steppers are really quite such that fan noise starts to become intrusive so a "fanless" PSU is a good move IMO.
                • David J
                  I recently changed to 0.9 degree steppers for the X and Y motors on my CoreXY - that made a huge difference to the noise level. The Duet board drives them properly and quietly. Not just that they are quiet in themselves, but the assorted resonances I was getting from the frame and its panels have also gone completely.
