    duetpimanagementplugin - how to reinstall 3.4b7
    Beta Firmware
      jay_s_uk
      Accidentally uninstalled the duetpimanagementplugin through DWC.
      Now I can't remove it or reinstall it. Anyone got any tips?
      This is the error
      sudo apt-get --purge autoremove duetpimanagementplugin
      Reading package lists... Done
      Building dependency tree
      Reading state information... Done
      The following packages will be REMOVED:
        duetpimanagementplugin*
      0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
      After this operation, 0 B of additional disk space will be used.
      Do you want to continue? [Y/n] y
      (Reading database ... 128946 files and directories currently installed.)
      Removing duetpimanagementplugin (3.4-b7) ...
      chmod: cannot access '/opt/dsf/plugins/DuetPiManagementPlugin.json': No such file or directory
      dpkg: error processing package duetpimanagementplugin (--remove):
       installed duetpimanagementplugin package pre-removal script subprocess returned error exit status 1
      chown: cannot access '/opt/dsf/plugins/DuetPiManagementPlugin.json': No such file or directory
      chown: cannot access '/opt/dsf/plugins/DuetPiManagementPlugin': No such file or directory
      chmod: cannot access '/opt/dsf/plugins/DuetPiManagementPlugin': No such file or directory
      Errors were encountered while processing:
      E: Sub-process /usr/bin/dpkg returned an error code (1)
      • chrishammundefined
        chrishamm administrators @jay_s_uk
        @jay_s_uk apt install --reinstall duetpimanagementplugin should work.
        Duet software engineer
          jay_s_uk @chrishamm
          @chrishamm said in duetpimanagementplugin - how to reinstall 3.4b7:
          unfortunately not
          sudo apt install --reinstall duetpimanagementplugin
          0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
          Need to get 0 B/4,896 kB of archives.
          Preparing to unpack .../duetpimanagementplugin_3.4-b7_armhf.deb ...
          dpkg: warning: old duetpimanagementplugin package pre-removal script subprocess returned error exit status 1
          dpkg: trying script from the new package instead ...
          dpkg: error processing archive /var/cache/apt/archives/duetpimanagementplugin_3.4-b7_armhf.deb (--unpack):
           new duetpimanagementplugin package pre-removal script subprocess returned error exit status 1
            @jay_s_uk Then run
            sudo touch /opt/dsf/plugins/DuetPiManagementPlugin.json
            sudo mkdir /opt/dsf/plugins/DuetPiManagementPlugin
            and try again
              jay_s_uk @chrishamm
              sudo touch /opt/dsf/plugins/DuetPiManagementPlugin.json sudo mkdir /opt/dsf/plugins/DuetPiManagementPlugin
              yes, that worked, thank you.
              might be worth preventing plugins installed through apt to not be uninstallable through DWC
              • jay_s_ukundefined jay_s_uk marked this topic as a question
              • jay_s_ukundefined jay_s_uk has marked this topic as solved
                @jay_s_uk Yes, AFAIR this already worked in previous versions but it's broken again in the latest one. I'll add more checks to the plugin service to ensure read-only plugins (like DuetPiManagementPlugin) cannot be removed using the web interface.
