Unsolved [3.4.0b7] Issue if filament_error.g contains M291
While playing around with filament_error.g I have found that if the macro contains an M291 call, the macro does not seem to terminate and the M291 does not display.
The macro sets a distance after the trigger point which may be extruded before pausing.
This is monitored in daemon.g;0:/sys/filament_error.g ;run when a filament sensor error is detected. Print will be paused by Daemon.g after runout distance. var runoutDistance = 350 ; this is just so you can change easily ; first check that we are not currently in an error state and the switch has been toggled again. if (global.filamentDistance !=0) || !(state.status = "processing") echo "Filament sensor triggered, but no print in progress. No action taken" M99 ; exit macro echo "filament_error.g run" G4 P10 ; delay 10ms to debounce if sensors.filamentMonitors[0].status="ok" echo "switch bounce detected - error cancelled" M99 ; break out if sensor value is zero again (bouncing) echo {"Filament error type " ^ param.P ^ " detected on extruder " ^ param.D} ;M291 R"Filament Error" P{"Filament error type " ^ param.P ^ " detected on extruder " ^ param.D} S1 T3 var thisExtruderValue = move.extruders[tools[state.currentTool].filamentExtruder].position set global.filamentDistance = var.thisExtruderValue + var.runoutDistance echo "filament_error.g run - print will be paused after " ^ var.runoutDistance ^ "mm"
@owend thanks for reporting this. I have added it to my list to investigate.
btw you could use the S parameter in your echo command:
echo {param.S}
This should display all the information about the error.
