    Firmware 3.4b7 - firmware retraction bug
    Beta Firmware
    3.5k
    • Diamondbackundefined
      Diamondback @Phaedrux
      @phaedrux said in Firmware 3.4b7 - firmware retraction bug:
      @Diamondback No it shouldn't damage anything. I think what happens is that the back emf equals the input voltage and the driver basically detects that as a possible disconnect.
      Have you shared your full config.g yet?
      Here you go:
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun May 10 2020 15:03:19 GMT+0200 (Mitteleuropäische Sommerzeit)
      ;M929 S3                                        ;enable debug logging
      M575 P1 S1 B57600                               ;Enable PanelDue Port
      G90                                             ; send absolute coordinates...
      M83                                             ; ...but relative extruder moves
      M550 P"V-Core Pro"                              ; set printer name
      M669 K1                                         ; select CoreXY mode
      M552 S1                                         ; enable network
      M569 P0 S0                                      ; stepper X/Y
      M569 P1 S0                                      ; stepper X/Y
      M569 P2 S1                                      ; stepper Coupler
      M569 P3 S0                                      ; stepper E1
      M569 P4 S0                                      ; stepper E2
      M569 P5 S0                                      ; stepper E3
      M569 P6 S0                                      ; stepper E4
      M569 P7 S0                                      ; stepper Z1
      M569 P8 S0                                      ; stepper Z2
      M569 P9 S0                                      ; stepper Z3
      M584 X0 Y1 C2 Z7:8:9                            ; set drive mapping (motion system)
      M584 E3:4:5:6                                   ; set drive mapping (extruders)
      if !exists(global.hasRunInit)
      	global minY = -266
      	global maxY = 115
      M208 X-148:160 Y{global.minY,global.maxY}       ; set axis minima & maxima				RRF 3.4
      M208 C0:250 Z-2:270                             ; set axis minima & maxima
      M671 X-203:-12:216 Y-179:222:-179 S30             ; set Z leadscrew positions
      M92 X80.00 Y80.00 C200.00 Z400.00               ; set steps per mm
      M350 X16 Y16 I1                                 ; configure microstepping with interpolation
      M350 C16 Z16 I1                                 ; configure microstepping with interpolation
      M566 X600 Y600 C2 Z70                           ; set maximum instantaneous speed changes (mm/min)
      M203 X30000 Y30000 C10000 Z3000                 ; set maximum speeds (mm/min)
      M201 X5000 Y5000 C500 Z500                      ; set accelerations (mm/s^2) was: 2k
      M204 P600 T5000
      M906 X2100 Y2100 I50                            ; set motor currents (mA) and motor idle factor in per cent
      M906 C500 I30                                   ; set motor currents (mA) and motor idle factor in per cent
      M906 Z1800 I50                                  ; set motor currents (mA) and motor idle factor in per cent
      M906 E500:500:500:500 I30                       ; set motor currents (mA) and motor idle factor in per cent (2x Flex3Drive 2x LGX)
      M84 S30                                         ; Set idle timeout
      ;=================== Extruder ======================
      M92 E408:408:408:408                            ; set steps per mm
      M350 E16:16:16:16 I1                            ; configure microstepping
      M566 E500:500:500:500                           ; set maximum instantaneous speed changes (mm/min) ; used to be at 1200
      M203 E15000:15000:15000:15000                   ; set maximum speeds (mm/min)
      M201 E3000:3000:3000:3000                       ; set accelerations (mm/s^2)
      M574 X2 S1 P"xstop"                             ; configure active-high endstop for high end on X via pin xstop
      M574 Y1 S1 P"ystop"                             ; configure active-high endstop for high end on Y via pin ystop
      M574 Z0                                         ; No Z-Endstop (use as probe instead)
      	global zProbeSpeedFeed = 250
      	global zProbeSpeedFeedLevel = 2100
      	global zProbeSpeedTravel = 20000
      	global zProbeDiveHeightLevel = 30
      	global zProbeDiveHeightMesh = 3
      	global zProbePin = "zstop"
      	global zProbeType = 8
      	global zProbeTriggerValue = 200
      	global minXMesh = -146
      	global maxXMesh = 150
      	global minYMesh = -150
      	global maxYMesh = 150
      	global meshPointSpacing = 30
      M558 K0 P{global.zProbeType} C{global.zProbePin} H{global.zProbeDiveHeightMesh} F{global.zProbeSpeedFeed} T{global.zProbeSpeedTravel}  ; default Z probe with slow speed
      ;M558 K0 P8 C"zstop" H3 F250 T20000  ; default Z probe with slow speed
      ;M558 K1 P8 C"zstop" H30 F2100 T20000  ; high speed Z probe for initial leveling and homing runs
      M558 K2 P8 C"duex.e5stop" H10 F100 T20000  ; set Z probe type to unfiltered switch and the dive height + speeds
      G31 K0 X0 Y0 Z0 P200
      ;G31 K1 X0 Y0 Z0 P200
      G31 K2 X0 Y0 Z0 P200
      ;G31 K0 X0 Y0 Z0 P{global.zProbeTriggerValue}                               ; set Z probe trigger value, offset and trigger height, offsets here are hardcoded in leveling macro as well
      M557 X{global.minXMesh, global.maxXMesh} Y{global.minYMesh, global.maxYMesh} S{global.meshPointSpacing}   ; define mesh grid
      M376 H30                                        ; Set bed correction taper
      M308 S0 P"bedtemp" Y"thermistor" T100000 B3950  ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0 Q10                       ; create bed heater output on bedheat and map it to sensor 0
      M143 H0 S121                                    ; set temperature limit for heater 0 to 121C
      M307 H0 B0 R0.676 C345.1 D2.68 S1.00 V24.3      ; Bed PID Tuning
      M140 H0                                         ; map heated bed to heater 0
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8  ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                            ; create nozzle heater output on e0heat and map it to sensor 1
      M143 H1 S301                                    ; set temperature limit for heater 1 to 301C
      M308 S2 P"e1temp" Y"thermistor" T100000 B4725 C7.06e-8  ; configure sensor 2 as thermistor on pin e1temp
      M950 H2 C"e1heat" T2                            ; create nozzle heater output on e1heat and map it to sensor 2
      M143 H2 S301                                    ; set temperature limit for heater 2 to 301C
      M308 S3 P"duex.e2temp" Y"thermistor" T100000 B4725 C7.06e-8  ; configure sensor 3 as thermistor on pin e2temp
      M950 H3 C"duex.e2heat" T3                            ; create nozzle heater output on e2heat and map it to sensor 3
      M143 H3 S301                                    ; set temperature limit for heater 3 to 301C
      M308 S4 P"duex.e3temp" Y"thermistor" T100000 B4725 C7.06e-8  ; configure sensor 2 as thermistor on pin e3temp
      M950 H4 C"duex.e3heat" T4                            ; create nozzle heater output on e3heat and map it to sensor 2
      M143 H4 S301                                    ; set temperature limit for heater 2 to 301C
      M302 S190 R190                                  ;Cold extrusion settings
      M307 H1 R4.637 K0.673:0.218 D2.31 E1.35 S1.00 B0 V24.2 ; PID Tuning T0
      M307 H2 R4.174 K0.555:0.276 D1.96 E1.35 S1.00 B0 V24.2 ; PID Tuning T1
      M307 H3 R4.301 K0.536:0.105 D1.89 E1.35 S1.00 B0 V24.2 ; PID Tuning T2
      M307 H4 R3.780 K0.576:0.060 D1.57 E1.35 S1.00 B0 V24.2 ; PID Tuning T3
      M950 F0 C"fan0"                                 ; Hotend Fan Tool 0
      M106 P0 S255 L255 H1 T50 C"T0 Hotend"           ; Hotend Fan Tool 0
      M950 F1 C"duex.fan3" Q50                        ; Layer Fan Tool 0
      M106 P1 S0 H-1 C"T0"                            ; Layer Fan Tool 0
      M950 F2 C"fan2"                                 ; Hotend Fan Tool 1
      M106 P2 S255 L255 H2 T50 C"T1 Hotend"           ; Hotend Fan Tool 1
      M950 F3 C"duex.fan4" Q50                        ; Layer Fan Tool 1
      M106 P3 S0 H-1 C"T1"                            ; Layer Fan Tool 1
      M950 F4 C"duex.fan5"                            ; Hotend Fan Tool 2
      M106 P4 S255 L255 H3 T50 C"T2 Hotend"           ; Hotend Fan Tool 2
      M950 F5 C"duex.fan6" Q50                        ; Layer Fan Tool 2
      M106 P5 S0 H-1 C"T2"                            ; Layer Fan Tool 2
      M950 F6 C"duex.fan7"                            ; Hotend Fan Tool 3
      M106 P6 S255 L255 H4 T50 C"T3 Hotend"           ; Hotend Fan Tool 3
      M950 F7 C"duex.fan8" Q50                        ; Layer Fan Tool 3
      M106 P7 S0 H-1 C"T3"                            ; Layer Fan Tool 3
      ;Static layer fan
      M950 F8 C"duex.e4heat" Q65535                   ; static layer fan
      M106 P8 S0 H-1 I1 L0.2 C"RSCS"
      M563 P0 D0 H1 F1                                ; define tool 0
      G10 P0 R0 S0                                    ; set initial tool 0 active and standby temperatures to 0C
      M563 P1 D1 H2 F3                                ; define tool 1
      G10 P1 R0 S0                                    ; set initial tool 1 active and standby temperatures to 0C
      M563 P2 D2 H3 F5                                ; define tool 2
      G10 P2 R0 S0                                    ; set initial tool 2 active and standby temperatures to 0C
      M563 P3 D3 H4 F7                                ; define tool 3
      G10 P3 R0 S0                                    ; set initial tool 3 active and standby temperatures to 0C
      M563 P4 S"Pen"                                  ; define tool 4 (Pen)
      ;Dock present switches
      M950 J0 C"e0stop"                               ; Tool 0 Dock switch
      M950 J1 C"e1stop"                               ; Tool 1 Dock switch
      M950 J2 C"duex.e2stop"                          ; Tool 2 Dock switch
      M950 J3 C"duex.e3stop"                          ; Tool 3 Dock switch
      ;additional tool related switches
      ;M950 J4 C"duex.e4stop"                          ;potential toolhead tool present switch
      ;M950 J5 C"duex.e5stop"                          ;Z Offset Calibration switch
      M950 S0 C"duex.pwm4"                            ;PebbleWiper Servo
      M950 P1 C"duex.pwm5"                            ;Light switch PWM
      ;Accelerometer
      M955 P0 C"spi.cs3+spi.cs4"
      ;M593 P"zvd" F60 ; Inputshaping
      M98 P"/macros/Misc/Lights/On"
      M98 P"/sys/config-tools.g"
      	global pebbleFeedSpeedDefault = 400
      	global pebbleFeedSpeed = global.pebbleFeedSpeedDefault
      	global deactivateToolAfterFilamentChange = false
      	global hasRunInit = true
      M42 P1 S230
      config-tools.g
      	global tool0NozzleSize = "0.0"
      	global tool1NozzleSize = "0.0"
      	global tool2NozzleSize = "0.0"
      	global tool3NozzleSize = "0.0"
      	global tool0NozzleMaterial = ""
      	global tool1NozzleMaterial = ""
      	global tool2NozzleMaterial = ""
      	global tool3NozzleMaterial = ""
      M98 P"/sys/config-tools-size.g"
      M98 P"/sys/config-tools-material.g"
      ;Z-Offset: 	If nozzle is too close to bed _reduce_ offset (negative number becomes more negative)
      ;		If nozzle is too far away, _increase_ offset (negative number becomes less negative)
      ;Tool offsets
      G10 P0 X-8.400 Y39.180 Z-4.100
      G10 P1 X-8.340 Y39.260 Z-4.080
      G10 P2 X-7.880 Y38.880 Z-4.310
      G10 P3 X-7.810 Y39.040 Z-4.576
      G10 P4 X0 Y46.5 Z-20.000                        ; set tool 4 axis offsets
      config-tools-size.g
      (This file is auto generated from my nozzle size selection UI in BtnCmd)
      set global.tool0NozzleSize = "0.4"
      set global.tool1NozzleSize = "0.4"
      set global.tool2NozzleSize = "0.4"
      set global.tool3NozzleSize = "0.4"
      config-tools-materials.g
      (This file is auto generated from my nozzle material selection UI in BtnCmd)
      set global.tool0NozzleMaterial = "brass"
      set global.tool1NozzleMaterial = "brass"
      set global.tool2NozzleMaterial = "brass"
      set global.tool3NozzleMaterial = "nozzlex"
        dc42 administrators @Phaedrux
        That's correct.
          dc42 administrators @Diamondback
          @diamondback are you using mesh bed compensation with taper when this issue occurs?
          Diamondbackundefined 1 Reply Last reply Reply Quote 1
            Diamondback @dc42
            @dc42 said in Firmware 3.4b7 - firmware retraction bug:
            I am indeed using a tapered mesh bed compensation, however, that only gets activated prior to starting a job. I don't think it gets deactivated afterwards though, so it might very well be active sometimes when this happens.
            Maybe that explains the seemingly random nature, doing filament changes after power-up vs after a print job...
            If you suspect that the mesh has something to do with it, is there a specific gcode I should try to put in my post print macro that deactivates the mesh again?
            Or would changing something abuot the taper help?
            I can't really turn off the mesh for actual printing I'm afraid.
              @diamondback thanks. One of our collaborators has tracked down a cause of extruder-only moves happening too fast, but he can only make it occur when bed compensation taper is in use. I am working on a fix to include in 3.4.2. Meanwhile can you try disabling bed compensation taper, to see if the problem still occurs?
              Diamondbackundefined 1 Reply Last reply Reply Quote 2
                Diamondback @dc42
                Ok, will disable it and see what happens 👍
                  @diamondback one more question: does the tool concerned have a nonzero Z offset?
                    Diamondback @dc42
                    It's a toolchanger where all 4 tools have non-zero offsets in all axis. (the toolhead/coupling/toolplate system is the one from E3D)
                      @diamondback @natthapol-v @danzaywer I have put new 3.4.2rc2+ firmware builds to fix this at https://www.dropbox.com/sh/7tf55ax00ky1pyx/AAA_eVJE20oYUON_gjKhCHsja?dl=0. I have tested the fix on the Duet 3 MB6HC build.
                      I was only able to reproduce this issue after when using tapered mesh bed compensation. Thanks for your patience.
                        Diamondback
                        Awesome, so with that updated firmware, using a taper shouldn't be an issue anymore?
                          @diamondback said in Firmware 3.4b7 - firmware retraction bug:
                          Correct.
                            Diamondback
                            So far, no issues. 👏 But haven't printed/changed filaments a lot yet
