    [3.4.0b7] Issue with Bed PID
    Beta Firmware
    • Fred-Yundefined
      Fred-Y
      I'm having troubles to properly PID the bed on my Predator, below is the log of the one I just did.
      12/24/2021, 2:30:58 PM	Warning: heater behaviour was not consistent during tuning
      Auto tuning heater 0 completed after 5 idle and 25 tuning cycles in 2856 seconds. This heater needs the following M307 command:
       M307 H0 R0.292 K0.227:0.000 D1.04 E1.35 S1.00 B0
      Send M500 to save this command in config-override.g
      12/24/2021, 1:55:28 PM	Auto tune starting phase 3, measuring
      12/24/2021, 1:48:39 PM	Auto tune starting phase 2, settling
      12/24/2021, 1:43:26 PM	Auto tune starting phase 1, heating up
      12/24/2021, 1:43:21 PM	M303 H0 S60
      Auto tuning heater 0 using target temperature 60.0°C and PWM 1.00 - do not leave printer unattended
      With the suggested values, the firmware triggers an error because it's not getting hot fast enough.
      Heater 0 fault: temperature rising too slowly: expected 0.24°C/sec measured 0.12°C/sec
      The diameter of the bed is 380cm and it has a magnetic sheet plus a 4mm glass on top of it (I often switch between PEI and glass), also the bottom of the bed is insulated - all of that is likely to create some thermal inertia.
      I'm pretty sure I didn't had this issue with 3.3 but I don't remember if it happen with the previous 3.4 beta - I don't mind testing specifics beta version or rolling back to 3.3 if this is useful.
      • CabalSoulundefined
        CabalSoul
        I’m having the same issue with my predator and a magnetic PEI sheet. Also insulated and with an enclosure.
        I’m re tuning my most common Temp ranges 58,70,85,110.
        I had some partial success(with completing a tuning process) , if I start my Bed PID tune already warmed up from a previous tuning process.
        Anycubic Predator, Orbiter Extruder , Duet Wifi, Mosquito Hotend, Remote Extruder Stepper cooling and Part cooling
        Exerqtorundefined 1 Reply Last reply Reply Quote 0
        • Exerqtorundefined
          Exerqtor @CabalSoul
          Have a look at this.
          Fred-Yundefined 1 Reply Last reply Reply Quote 1
          • Fred-Yundefined
            Fred-Y @Exerqtor
            @exerqtor Thanks for the tip!
            I installed b7+1 and rerun the PID, I had the same warning and similar parameters.
            Auto tuning heater 0 completed after 6 idle and 25 tuning cycles in 2947 seconds. This heater needs the following M307 command:
             M307 H0 R0.292 K0.273:0.000 D1.04 E1.35 S1.00 B0
            But it seems that now I can heat the bed without any issue, I try in the next few days to heat it from room temperature.
            • Fred-Yundefined
              Fred-Y
              With the exception of the PID warning "heater behaviour was not consistent during tuning" which might be caused by my tick bed everything appears to know be fine with b7+1, from my perspective I think this issue can be marked as resolved.
