    UM2 Homing Issues
    • Ripeds_O3Pundefined
      Ripeds_O3P
      I've got homing issues for my Ultimaker 2. Here's what it does when I hit Home All in the dashboard:
      • Z axis homes first hitting the end switch (no issues there)
      • Next Y axis homes (hitting the switch, no issues)
      • Finally X axis, where it hits the end switch. From there I can hear the stepper motor grinding. Where the printer ultimately gets stuck.
      Ideas for fixing my homing issues?
      config.g
      homez.g
      homey.g
      homex.g
      homeall.g
        Ripeds_O3P
        Additional notes:
        • My firmware version is 2.05.1.
        • The config and homing files were frankensteined together from the old files of two others for their Duets on the UM2.
        • Would this issue be gone if the Z axis is last to be homed? How does one go about making Z go last?
        Stephen6309undefined 1 Reply Last reply Reply Quote 0
        • Stephen6309undefined
          Stephen6309 @Ripeds_O3P
          @ripeds_o3p Sounds like the X axis endstop isn't setup correctly. Use M119 to make sure the X axis endstop is responding correctly.
          Ripeds_O3Pundefined 1 Reply Last reply Reply Quote 0
            Ripeds_O3P @Stephen6309
            @stephen6309 I appreciate the response. I actually made a breakthrough forty minutes ago. A clean homing sequence with no motor grinding. X & Y went first, then Z.
            Aloooot of research went into getting that result. I hope any future hurdles are easier to tackle.
            I still have more things to test with the printer. But things are looking up now.
