    Use M591 filament sensor for CNC enclosure door
    Firmware wishlist
    • EducatingSavvasundefined
      EducatingSavvas
      This is an idea for use with routers milling and laser machines - could the M591 filament sensor command be expanded to work with an enclosure door - which if left open or opened during a job, pauses and forbids any movement?
      Alex.crundefined 1 Reply Last reply Reply Quote 1
      • Alex.crundefined
        Alex.cr @EducatingSavvas
        @educatingsavvas
        This is already possible using triggers.
        This link should get you started. This was set up for 2.0 firmware. If you are using 3.0 firmware it will need to be adapted. It’s a place to start at least.
        Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
        EducatingSavvasundefined 1 Reply Last reply Reply Quote 1
          EducatingSavvas @Alex.cr
          @alex-cr Hi Alex - I've used triggers but since going from RRF3.3 to RRF3.4beta7 there seems to be an issue with resuming. I think something as safety critical as an interlock should be defined by it's own gcode. It's just a suggestion, as some workflows seems to be overlooked.
          For example using M291 S3 command in a start.g file doesn't cancel the job about to commence if the message is cancelled.
