    Temperatur offset
    • Topengaundefined
      Topenga
      Hello together,
      I have a significant difference between Nozzle and heated bed temperatures when heaters are off.
      Is there a possibility to measure the real temperatures and to adjust the offset somehow?
      Does that makes sense? I struggle that the real temperatures are quite to low....
      Here my config:
      M143 H0 S110 ; set temperature limit for heater 0 to 110C
      M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs1
      M143 H1 S350 ; set temperature limit for heater 1 to 350C
      Many thanks in advance
      Danijel T.
      cosmowaveundefined 1 Reply Last reply Reply Quote 0
      • cosmowaveundefined
        cosmowave @Topenga
        @topenga said in Temperatur offset:
        How big is the difference?
        Mankati FSXT+, DeltaTowerV2, E3D MS/TC
        Topengaundefined 1 Reply Last reply Reply Quote 0
        • Topengaundefined
          Topenga @cosmowave
          @cosmowave said in Temperatur offset:
          The difference is between 8 and 10 degrees.
          Thx
            dc42 administrators @Topenga
            @topenga see https://duet3d.dozuki.com/Wiki/Calibrating_thermistor_and_PT1000_readings. Your PT100 reading should be accurate, unless you are using a 2-wire connection and you have significant resistance in the cable to the PT100 (in which case it will read 1C high for every 0.4 ohms of resistance); but you may need to calibrate the bed thermistor input.
            • Topengaundefined
              Topenga @dc42
              @dc42 said in Temperatur offset:
              Hello DC42,
              Thanks for answer.... Will try and return the outcome!
              Danijel T.
