    Was working, now can't connect to WiFi
    824
    • flyeyesundefined
      flyeyes
      Duet 3 mini 5+
      Initial setup was nominal, except for failing to setup a static IP address, so it took me a minute to find it if I power cycled my router. Using a Mac and Serial Tools to connect, then DWC.
      Worked fine for a bit, was able to get the printer configured, stops calibrated, heaters, etc all working as expected. Once or twice lost WiFi connectivity, but power cycling the printer fixed it, then a couple of times had to plug in the USB cable and use M552 to turn on the WiFi for it to work.
      Now it refuses to connect to WiFi, antenna is secure and undamaged. Network is fine, other devices having no trouble. I can connect with Serial tools over USB, but I keep getting the "WiFi reported error: no known networks found" followed by WiFi module is idle.
      I've tried all the iterations of M552 to turn it off and on, have tried M587, M588, and M589 to refresh the network parameters, but nothing seems to work.
      Where from here?
        Can you share the results of M122 both when it's connected to wifi and when it's not?
        flyeyesundefined 3 Replies Last reply Reply Quote 0
        • flyeyesundefined
          flyeyes @Phaedrux
          @phaedrux
          Give me a minute and I'll try it connected to USB.
          I can't do connected to WiFi since it will no longer connect.
          • flyeyesundefined
            flyeyes @Phaedrux
            @phaedruxm552 s1
            m552
            m552
            WiFi module is disabled
            ok
            m552 s1
            ok
            WiFi module started
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            M122
            RepRapFirmware for Duet 3 Mini 5+ version 3.3RC2 (2021-05-11 14:55:40) running on Duet 3 Mini5plus WiFi (standalone mode)
            Board ID: D79UH-2096U-D65J0-40KMU-0G03Z-R76Y7
            Used output buffers: 1 of 40 (1 max)
            Static ram: 102476
            Dynamic ram: 104660 of which 420 recycled
            Never used RAM 36148, free system stack 145 words
            Tasks: NETWORK(ready,7.1%,520) HEAT(delaying,0.0%,390) Move(notifyWait,0.1%,362) CanReceiv(notifyWait,0.0%,943) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,341) TMC(notifyWait,0.0%,124) MAIN(running,91.3%,607) IDLE(ready,0.7%,29) AIN(delaying,0.8%,274), total 100.0%
            Owned mutexes: USB(MAIN)
            Last reset 00:00:18 ago, cause: power up
            Last software reset at 2021-12-31 14:04, reason: User, GCodes spinning, available RAM 35076, slot 0
            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
            Error status: 0x00
            Aux0 errors 0,0,0
            Aux1 errors 0,0,0
            MCU revision 3, ADC conversions started 18852, completed 18852, timed out 0, errs 0
            Step timer max interval 732
            MCU temperature: min 16.0, current 19.8, max 19.8
            Supply voltage: min 0.1, current 0.7, max 0.7, under voltage events: 0, over voltage events: 0, power good: no
            Driver 0: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
            Driver 1: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
            Driver 2: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
            Driver 3: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
            Driver 4: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
            Driver 5: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
            Driver 6: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
            Cache data hit count 41054978
            Slowest loop: 10.13ms; fastest: 0.11ms
            === Storage ===
            Free file entries: 10
            SD card longest read time 3.1ms, write time 0.0ms, max retries 0
            === MainDDARing ===
            === AuxDDARing ===
            Bed heaters = -1 -1, chamberHeaters = -1 -1
            Segments left: 0
            Movement lock held by null
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is ready with “M122” in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            SBC is idle in state(s) 0
            Daemon is idle in state(s) 0
            Aux2 is idle in state(s) 0
            Code queue is empty.
            === CAN ===
            Messages queued 94, send timeouts 93, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
            Last cancelled message type 30 dest 127
            === Network ===
            Slowest loop: 0.16ms; fastest: 0.00ms
            HTTP sessions: 0 of 8
            • WiFi -
              Network state is disabled
              Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485
              ok
            • flyeyesundefined
              flyeyes @Phaedrux
              @phaedrux
              and to be clear, I've repeatedly used M552 with the S and P parameters for the SSID and password, and they worked fine until they didn't
              I've also tried using M588 to delete the network and attempt to replace the parameters again with M587 (as well as M552)
              If it means anything I think the last thing I tried to do before it quit working was use the M552 with the P, S, and I parameters to fix an IP address so I didn't have to sniff the network every time the router changed it.
                Phaedrux Moderator @flyeyes
                @flyeyes said in Was working, now can't connect to WiFi:
                Can you use this procedure to update your firmware?
                https://duet3d.dozuki.com/Wiki/Duet_3_Mini_5plus_Firmware#Section_Updating_firmware_via_USB
                If that doesn't help, send M997 S1 to reflash the wifi server firmware as well. You may need to first manually place the wifi server bin file onto the SD card in a new folder called firmware on the root of the SD card if it doesn't already exist as that is where it will be looking in 3.3
                https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/DuetWiFiServer.bin
                flyeyesundefined 1 Reply Last reply Reply Quote 0
                • flyeyesundefined
                  flyeyes @Phaedrux
                  @phaedrux
                  I've tried that now 3x. Can connect through serial as before, but no WiFi.
                  Removed MicroSD card, placed in computer and manually replaced the DuetWiFiServer.bin file 3x (twice on a Mac, once on a windows machine for grins) but M997 returns an error:
                  Error: M997: File 0:/firmware/DuetWiFiServer.bin not found
                  The file is in the sys directory, where I found it originally.
                  Quite frustrated, was chasing down the final hardware details and now can't run the printer.
                  I do have a Pi 4 available, should I just try that and give up on the Duet WiFi?
                  flyeyesundefined 1 Reply Last reply Reply Quote 1
                  • flyeyesundefined
                    flyeyes @flyeyes
                    @flyeyes
                    my bad, just realized it was in the wrong directory. moved it and now updated, but same problem: no WiFi connectivity
                    It was working fine until it wasn't, network is fine.
                      Ok so what does M122 return now?
                      How bout these commands
                      M552
                      M552 S-1
                      M552 S0
                      M552 S1
                      M588 S"*"
                      M587
                      flyeyesundefined 2 Replies Last reply Reply Quote 0
                      • flyeyesundefined
                        flyeyes @Phaedrux
                        @phaedrux
                        m587
                        Remembered networks: none
                        ok
                        m122
                        RepRapFirmware for Duet 3 Mini 5+ version 3.3 (2021-06-15 21:46:11) running on Duet 3 Mini5plus WiFi (standalone mode)
                        Static ram: 102724
                        Dynamic ram: 104600 of which 464 recycled
                        Never used RAM 35916, free system stack 145 words
                        Tasks: NETWORK(ready,7.3%,520) HEAT(delaying,0.0%,420) Move(notifyWait,0.1%,362) CanReceiv(notifyWait,0.0%,941) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,340) TMC(notifyWait,0.0%,124) MAIN(running,91.4%,629) IDLE(ready,0.4%,29) AIN(delaying,0.8%,274), total 100.0%
                        Last reset 00:00:30 ago, cause: power up
                        Error status: 0x00
                        MCU revision 3, ADC conversions started 30540, completed 30540, timed out 0, errs 0
                        Step timer max interval 731
                        MCU temperature: min 16.9, current 20.4, max 20.6
                        Supply voltage: min 0.2, current 0.7, max 0.7, under voltage events: 0, over voltage events: 0, power good: no
                        Cache data hit count 66198261
                        Slowest loop: 9.62ms; fastest: 0.11ms
                        === Storage ===
                        === MainDDARing ===
                        === AuxDDARing ===
                        Segments left: 0
                        USB is ready with “m122” in state(s) 0
                        === CAN ===
                        Messages queued 153, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17), ts 153/0/0
                        Tx timeouts 0,0,152,0,0,0 last cancelled message type 30 dest 127
                        === Network ===
                        • WiFi -
                          ok
                        • flyeyesundefined
                          flyeyes @Phaedrux
                          @phaedrux
                          tried to send more, but "flagged as spam."
                          587 returns no remembered networks. Have tried reentering SSID and password probably 30+ times
                          Phaedruxundefined 1 Reply Last reply Reply Quote 1
                            Try again.
                            What error do you get when you try to enter the SSID?
                            What do these produce?
                            M552
                            M552 S-1
                            M552 S0
                            M552 S1
                            M588 S"*"
                            • flyeyesundefined
                              flyeyes @Phaedrux
                              @phaedrux
                              All of those are in the above messages, but to recap:
                              M552 returns "no remembered networks"
                              M552 S1 returns many, many lines of no network available
                              M552 S0 works as expected
                              M588 S"*" erased all of the networks as expected, but I cannot add the SSID and password back. Have tried dozens of times (literally)
                              • flyeyesundefined
                                flyeyes @Phaedrux
                                @phaedrux
                                I did get it to work briefly (just now) while connected to serial (I've been doing the exact same thing dozens of times for days without success) but its still wonky. the WiFi will hook up while I'm connected to serial via USB, but I lose it and it won't connect if I unplug the USB and then power the board up normally.
                                I know documentation says to not use USB and an external power supply at the same time, but I did try briefly to get the WiFi going on USB, turn on the printer, and unplug WiFi.
                                This worked until I rebooted the board, and no connectivity after that. Got it going again with USB, but can't power cycle without losing connectivity
                                  So does it have a saved SSID now or not?
                                  Does your config.g have a M552 S1?
                                  The last test would be to see if it will run in standalone WIFI access point mode.
                                  https://duet3d.dozuki.com/Wiki/M589
                                  • flyeyesundefined
                                    flyeyes @Phaedrux
                                    @phaedrux
                                    Yes, it seems to be working now. I have no idea what I did differently, which bothers me a bit because it worked fine when I first configured it, then after a week quit working, and now it’s working fine as far as I can tell.
                                    I haven’t done anything differently, but I will watch it for now. If it quits again I’m just going to plug it into the pi or start over with a different board.
                                      Well if we can identify what's wrong or if there is something wrong and it's under warranty you can get it replaced.
                                      • terbospaghettiundefined
                                        terbospaghetti
                                        I'm having this same problem.
                                        I can save and forget networks as long as the wifi module has been set to active with m552 S0, but not with S-1 or S1 modifiers. When I try to check the status of the wifi module with M552 by itself, I consistently get "wifi module is changing modes" until there's an SPI timeout message like the one at the bottom of the excerpt below.
                                        I've successfully reinstalled wifiserver.bin twice (i'm doing this over USB with pronterface and a 24vPSU for the board), but this has yielded no changes in anything. If I just let it sit, it'll eventually give me a bunch of these in a row:
                                        WiFi module is idle
                                        WiFi reported error: network scan failed
                                        WiFi module is idle
                                        WiFi module is idle
                                        WiFi module is idle
                                        WiFi module is idle
                                        WiFi module is idle
                                        WiFi module is idle
                                        WiFi module is idle
                                        WiFi module is idle
                                        WiFi module is idle
                                        WiFi module is idle
                                        WiFi module is idle
                                        WiFi module is idle
                                        WiFi module is idle
                                        WiFi module is idle
                                        Error retrieving WiFi status message: SPI timeout
                                        WiFi module is idle
                                        Failed to change WiFi mode: SPI timeout
                                        Once the SPI timeout message(s) come, m552 reports that the wifi module is disabled.
                                        I know it's not a poor signal issue, as I've tried within a foot or two of the router.
                                        Here's my m122 if it helps:
                                        >>> M122
                                        SENDING:M122
                                        Board ID: ZJ21Z-NV9RL-D65J0-40KMN-L3X2Z-HFGNV
                                        Used output buffers: 1 of 40 (40 max)
                                        Static ram: 102724
                                        Dynamic ram: 106504 of which 0 recycled
                                        Never used RAM 34476, free system stack 157 words
                                        Tasks: NETWORK(ready,7.6%,328) HEAT(notifyWait,0.0%,364) Move(notifyWait,0.1%,362) CanReceiv(notifyWait,0.0%,941) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,340) TMC(notifyWait,1.1%,115) MAIN(running,90.4%,426) IDLE(ready,0.0%,29) AIN(delaying,0.8%,264), total 100.0%
                                        Last reset 00:14:30 ago, cause: software
                                        Last software reset at 2022-01-09 18:47, reason: StuckInSpinLoop, Display spinning, available RAM 41956, slot 1
                                        Software reset code 0x408f HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0043380f BFAR 0xe000ed38 SP 0x20002a4c Task IDLE Freestk 43 ok
                                        Stack: 00087e75 000888a8 61000000 a5a5a5a5 00087e75 a5a5a5a5 a5a5a5a5 2000390c 0001676d 20019104 2002ec9c 20002a68 200190fc 00000004 2001e0dc 2001e0dc 20002a68 2001e0d4 00000001 20002ac4 4e49414d 00000000 00000000 00000001 00000001 17c2fb96 00000000
                                        Error status: 0x04
                                        Error status: 0x04
                                        Aux0 errors 0,0,1
                                        MCU revision 3, ADC conversions started 870849, completed 870849, timed out 0, errs 0
                                        Step timer max interval 597
                                        MCU temperature: min 26.1, current 33.1, max 33.3
                                        Supply voltage: min 23.9, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                                        Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 13591, writes 9, timeouts 0, DMA errors 0
                                        Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 13591, writes 9, timeouts 0, DMA errors 0
                                        Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 13591, writes 9, timeouts 0, DMA errors 0
                                        Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 13591, writes 9, timeouts 0, DMA errors 0
                                        Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 13591, writes 9, timeouts 0, DMA errors 0
                                        Driver 5: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 13591, writes 9, timeouts 0, DMA errors 0
                                        Driver 6: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 13591, writes 9, timeouts 0, DMA errors 0
                                        Cache data hit count 1789008195
                                        Slowest loop: 99.69ms; fastest: 0.12ms
                                        === Storage ===
                                        SD card longest read time 0.5ms, write time 0.0ms, max retries 0
                                        === MainDDARing ===
                                        === AuxDDARing ===
                                        Bed heaters = 0 -1, chamberHeaters = -1 -1
                                        Segments left: 0
                                        USB is ready with "M122" in state(s) 0
                                        Aux is assembling a command in state(s) 0
                                        === CAN ===
                                        Messages queued 7836, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17), ts 4354/0/0
                                        Tx timeouts 0,0,4353,0,0,3481 last cancelled message type 4514 dest 127
                                        === Network ===
                                        Slowest loop: 200.13ms; fastest: 0.00ms
                                        - WiFi -
                                        Failed messages: pending 0, notready 0, noresp 2
                                          Phaedrux Moderator @terbospaghetti
                                          @terbospaghetti said in Was working, now can't connect to WiFi:
                                          That's normal.
                                          The M587 command will fail if the WiFi module has not yet been taken out of reset. So if the WiFi module has not been started, send M552 S0 to put it in idle mode first.
                                          https://duet3d.dozuki.com/Wiki/M587
                                          Not normal.
                                          Have you been able to verify that the correct version is installed with a M122 when the wifi has connected?
                                          terbospaghettiundefined 1 Reply Last reply Reply Quote 0
                                            terbospaghetti @Phaedrux
                                            @phaedrux said in Was working, now can't connect to WiFi:
                                            Not sure where I would look or what it should say, but the process was successful according to the console in pronterface
