Homing/Motor control Issues
Ive got an Ooznest Workbee that ive just upgraded to a Duet 3 MB 6HC.
ive updated it to 3.3 and installed Workbee Control. I have changed all the Endstop and relevant definitions in the config files to suit the Duet 3 as workbee control is intended for Duet 2
Im having problems with the X Axis motor (Driver 0) losing all holding/moving power after using HOME ALL.
If i home X on its own from a fresh power up it will home fine and when done will hold its place ang jog about fine. If i home X first then home Y, or do a HOME ALL (does it in same order) once all have homed the X axis has no holding torque and cannot jog about or re-home. If i hold the motor i can feel a slight rumble if i try to jog it, suggesting that the driver hasnt been turned off completely, maybe the current limit has been reduced drastically?
While retreating back to the main pc to sit down and check the homing files etc i came back to the machine and X axis was suddenly working and no matter what order i homed the axes there after it wouldnt repeat the problem. If power cycled it will revert to losing the x axis after HOME ALL or homing X first then Y. If i manually Home Y first then Home X from a fresh power on I can do whatever I like and X will never drop out even if i use HOME ALL or home X then Y.
I haven't tried to use the machine for anything yet as i dont have much faith in not knowing why X is dropping out, and even stranger why it will come back if left for a while.
I'm at a loss, ive double checked all the wiring, im convinced its something software but cant seem to see what could be causing this behaiviour.
Cheers
Rich -
@rich1351 Please post your homing files as code.
@theolodian here are the homing fileshomey.g homex.g homeall.g
it wouldnt post if i added them as code kept saying flagged as spam -
@rich1351 Yeah, I don't see any typos there. Sorry, beyond me.
Post your config.g please and Can you send M122 and M98 P"config.g" in the Gcode console in DWC and post the results?
config-spindle.g config-drives.g config-axes-limits.g config-axes-endstops.g config-axes-calibration.g config-axes.g config.g
ill have to upload the rest in another reply as it will only allow so many
The results from M122:
M122
RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v1.01 or later (standalone mode)
Board ID: 08DJM-956BA-NA3TJ-6J9F0-3S86L-1V9LT
Used output buffers: 1 of 40 (22 max)
Static ram: 150904
Dynamic ram: 91664 of which 0 recycled
Never used RAM 108768, free system stack 206 words
Tasks: NETWORK(ready,31.4%,212) ETHERNET(notifyWait,0.2%,126) HEAT(delaying,0.0%,405) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,333) TMC(notifyWait,7.4%,93) MAIN(running,60.8%,924) IDLE(ready,0.1%,29), total 100.0%
Owned mutexes:
Last reset 00:07:18 ago, cause: power up
Last software reset details not available
Error status: 0x00
Step timer max interval 158
MCU temperature: min 25.1, current 25.7, max 26.0
Supply voltage: min 23.8, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0
Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/24/0, gc cycles 0
Driver 0: position 0, standstill, reads 56989, writes 0 timeouts 0, SG min/max not available
Driver 1: position 0, standstill, reads 56989, writes 0 timeouts 0, SG min/max not available
Driver 2: position 0, standstill, reads 56989, writes 0 timeouts 0, SG min/max not available
Driver 3: position 0, standstill, reads 56989, writes 0 timeouts 0, SG min/max not available
Driver 4: position 0, standstill, reads 56989, writes 0 timeouts 0, SG min/max not available
Driver 5: position 0, standstill, reads 56989, writes 0 timeouts 0, SG min/max not available
Date/time: 2022-01-07 10:20:05
Slowest loop: 13.59ms; fastest: 0.05ms
=== Storage ===
Free file entries: 10
SD card 0 detected, interface speed: 25.0MBytes/sec
SD card longest read time 3.2ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== CAN ===
Messages queued 521, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 49), ts 521/0/0
Tx timeouts 0,0,521,0,0,0 last cancelled message type 30 dest 127=== Network ===
Slowest loop: 13.77ms; fastest: 0.02ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
HTTP sessions: 2 of 8- Ethernet -
State: active
Error counts: 0 0 1 0 0
Socket states: 5 2 2 2 2 0 0 0
The results from M98 P"config.g":
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Error: Tool 49 not found - Ethernet -
remaining config files config-user-settings.g config-probe.g config-override.g config-network.g config-laser.g config_default.g
After some more testing I've swapped the x axis to driver 4 and all works as should no dropping out whatsoever so I have a feeling this board has a fault on driver 0 unless something in software is messing with driver 0
@rich1351 bump
Do you get any error messages when it's not moving? The description makes it sound like intermittent wiring issue. I don't see anything in your configs, but it's also very spread out so maybe I missed something.
@phaedrux no error messages, the readouts update as if it has moved. with just the change to driver 4 in config-axes.g and reversing the motor direction in config-drives.g it works flawlessly, ive tested it both ways with the routed wiring, and also made up a single motor wire to eliminate the other wiring and with both it acts exactly the same. I have spoken to ooznest where i purchased the board and they have advised it may be faulty but i need to get comfirmation from this forum to get the warranty claim sorted
Cheers
Rich -
Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
