    Y axis motor just stops working
    Using Duet Controllers
    • Stephen6309undefined
      Stephen6309
      Y axis motor just stops working, but X and the extruder keep going. Can move it with no resistance when it occurs. Pully is tight and belt is fine. Requires a reset to work again.
      Duet 3 Mini 5+ with 1LC
      Firmware 3.4.0.beta7 on both, DWC 3.3 b-7
      M122 after error:
      m122
      RepRapFirmware for Duet 3 Mini 5+ version 3.4.0beta7 (2021-12-16 12:22:56) running on Duet 3 Mini5plus WiFi (standalone mode)
      Board ID: BXM1Y-Z196U-D65J0-40KMJ-4U03Z-7VGG6
      Used output buffers: 9 of 40 (40 max)
      Static ram: 103460
      Dynamic ram: 108956 of which 56 recycled
      Never used RAM 25352, free system stack 112 words
      Tasks: NETWORK(ready,84.6%,232) HEAT(notifyWait,0.1%,342) Move(notifyWait,8.7%,265) CanReceiv(notifyWait,0.2%,772) CanSender(notifyWait,0.1%,364) CanClock(delaying,0.0%,337) TMC(notifyWait,3.6%,105) MAIN(running,100.6%,420) IDLE(ready,0.6%,29) AIN(delaying,4.3%,264), total 202.8%
      Owned mutexes:
      Last reset 07:54:36 ago, cause: power up
      Last software reset at 2022-01-04 11:56, reason: User, GCodes spinning, available RAM 26676, slot 1
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x04
      Aux0 errors 0,0,0
      MCU revision 3, ADC conversions started 28477747, completed 28477747, timed out 0, errs 0
      Step timer max interval 1490
      MCU temperature: min 22.6, current 40.1, max 45.6
      Supply voltage: min 23.7, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/548/496, gc cycles 0
      Events: 0 queued, 0 completed
      Driver 0: pos 0, standstill, SG min 0, read errors 0, write errors 0, ifcnt 37, reads 55962, writes 37, timeouts 0, DMA errors 0, CC errors 0
      Driver 1: pos 24668, standstill, SG min 0, read errors 0, write errors 0, ifcnt 38, reads 55961, writes 38, timeouts 0, DMA errors 0, CC errors 1
      Driver 2: pos 48533, standstill, SG min 0, read errors 0, write errors 0, ifcnt 37, reads 55961, writes 37, timeouts 0, DMA errors 0, CC errors 0
      Driver 3: pos 0, standstill, SG min 0, read errors 0, write errors 0, ifcnt 37, reads 55960, writes 37, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x6a
      Driver 4: pos 0, standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 55990, writes 9, timeouts 0, DMA errors 0, CC errors 0
      Driver 5: pos 0, ok
      Driver 6: pos 0, ok
      Date/time: 2022-01-11 16:40:20
      Slowest loop: 124.81ms; fastest: 0.07ms
      === Storage ===
      Free file entries: 8
      SD card longest read time 3.3ms, write time 32.9ms, max retries 0
      DMs created 83, segments created 43, maxWait 2794147ms, bed compensation in use: mesh, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 91988, completed 91988, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === AuxDDARing ===
      Bed heaters 0 -1, chamber heaters -1 -1, ordering errs 0
      Heater 0 is on, I-accum = 0.0
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is doing "G4 P500 " in state(s) 0 0, running macro
      Aux2 is idle in state(s) 0
      Code queue is empty
      === CAN ===
      Messages queued 779188, received 570125, lost 0, boc 0
      Longest wait 3ms for reply type 6053, peak Tx sync delay 384, free buffers 17 (min 6), ts 142383/142382/0
      Tx timeouts 0,0,0,0,0,0
      === Network ===
      Slowest loop: 140.54ms; fastest: 0.00ms
      Responder states: HTTP(2) HTTP(2) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is active
      WiFi firmware version 1.26
      WiFi MAC address f4:cf:a2:6f:be:43
      WiFi Vcc 3.34, reset reason Power up
      WiFi flash size 2097152, free heap 24072
      WiFi IP address 192.168.50.11
      WiFi signal strength -34dBm, mode 802.11n, reconnections 0, sleep mode modem
      Clock register 00002002
      Socket states: 4 4 0 0 0 0 0 0
      M122 after reset and Home Y:
      m122
      Used output buffers: 8 of 40 (22 max)
      Static ram: 103460
      Dynamic ram: 108708 of which 12 recycled
      Never used RAM 26460, free system stack 130 words
      Tasks: NETWORK(ready,12.0%,230) HEAT(notifyWait,0.0%,376) Move(notifyWait,0.0%,270) CanReceiv(notifyWait,0.0%,772) CanSender(notifyWait,0.0%,372) CanClock(delaying,0.0%,346) TMC(notifyWait,0.7%,114) MAIN(running,86.2%,428) IDLE(ready,0.3%,29) AIN(delaying,0.8%,266), total 100.0%
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:01:33 ago, cause: software
      Last software reset at 2022-01-11 16:48, reason: User, GCodes spinning, available RAM 25352, slot 2
      Error status: 0x00
      Aux0 errors 0,0,0
      MCU revision 3, ADC conversions started 93073, completed 93073, timed out 0, errs 0
      Step timer max interval 751
      MCU temperature: min 38.5, current 38.7, max 39.4
      Supply voltage: min 23.8, current 23.9, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/12/0, gc cycles 0
      Driver 0: pos 0, standstill, SG min 2, read errors 0, write errors 1, ifcnt 50, reads 4876, writes 11, timeouts 0, DMA errors 0, CC errors 0
      Driver 1: pos 0, standstill, SG min 0, read errors 0, write errors 1, ifcnt 54, reads 4872, writes 14, timeouts 0, DMA errors 0, CC errors 0
      Driver 2: pos -1, standstill, SG min 0, read errors 0, write errors 1, ifcnt 53, reads 4872, writes 14, timeouts 0, DMA errors 0, CC errors 0
      Driver 3: pos 0, standstill, SG min 0, read errors 0, write errors 1, ifcnt 53, reads 4872, writes 14, timeouts 0, DMA errors 0, CC errors 0
      Driver 4: pos 0, standstill, SG min 0, read errors 0, write errors 1, ifcnt 19, reads 4877, writes 9, timeouts 0, DMA errors 0, CC errors 0
      Driver 5: pos 0, ok
      Driver 6: pos 0, ok
      Date/time: 2022-01-11 16:49:58
      Cache data hit count 161301813
      Slowest loop: 5.68ms; fastest: 0.07ms
      === Storage ===
      Free file entries: 9
      SD card longest read time 2.6ms, write time 0.0ms, max retries 0
      DMs created 83, segments created 9, maxWait 27558ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 5, completed 5, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === AuxDDARing ===
      Segments left: 0
      Code queue is empty
      === CAN ===
      Messages queued 860, received 1884, lost 0, boc 0
      Longest wait 2ms for reply type 6026, peak Tx sync delay 470, free buffers 17 (min 16), ts 466/465/0
      === Network ===
      Slowest loop: 133.80ms; fastest: 0.00ms
      - WiFi -
      WiFi flash size 2097152, free heap 24400
      WiFi signal strength -39dBm, mode 802.11n, reconnections 0, sleep mode modem
      config.g:
      ; Configuration file for Duet 3 Mini 5+ (firmware version 3)
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun May 16 2021 12:00:09 GMT-0400 (Eastern Daylight Time)
      G90                                                       ; send absolute coordinates...
      M83                                                       ; ...but relative extruder moves
      M550 P"M-Max"                                             ; set printer name
      M669 K0                                                   ; Cartesion mode
      M552 S1                                                   ; enable network
      M586 P0 S1                                                ; enable HTTP
      M586 P1 S0                                                ; disable FTP
      M586 P2 S0                                                ; disable Telnet
      M569 P0.0 S1                                              ; physical drive 0.0 goes forwards
      M569 P0.1 S1                                              ; physical drive 0.1 goes forwards
      M569 P0.2 S0                                              ; physical drive 0.2 goes backwards
      M569 P0.3 S0
      G4 S1
      M569 P121.0 S0                                            ; physical drive 121.0 goes backwards
      M584 X0.0 Y0.1 Z0.2:0.3 E121.0                                ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                                   ; configure microstepping with interpolation
      M92 X88.10 Y88.10 Z2133.30 E836.00                        ; set steps per mm
      M566 X600.00 Y80.00 Z30.00 E600.00                       ; set maximum instantaneous speed changes (mm/min)
      M203 X15000.00 Y15000.00 Z180.00 E1200.00                 ; set maximum speeds (mm/min)
      M201 X4000.00 Y2000.00 Z50.00 E250.00                     ; set accelerations (mm/s^2)
      ;M906 X1000 Y1200 Z800 E1200 I30                          ; set motor currents (mA) and motor idle factor in per cent
      M906 X1000 Y1000 Z800 E1200 I30                           ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                   ; Set idle timeout
      M208 X0 Y0 Z0 S1                                          ; set axis minima
      M208 X300 Y280 Z210 S0                                    ; set axis maxima
      M574 X1 S1 P"io5.in"                                      ; configure active-high endstop for low end on X via pin io5.in
      M574 Y1 S1 P"io6.in"                                      ; configure active-high endstop for low end on Y via pin io6.in
      M574 Z1 S2                                                ; configure Z-probe endstop for low end on Z
      M950 S0 C"121.io0.out"                                    ; create servo pin 0 for BLTouch
      M558 P9 C"^121.io0.in" H5 F120 T6000                      ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-30 Y0 Z0                                       ; set Z probe trigger value, offset and trigger height
      M557 X10:270 Y5:295 S40                                   ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4092              ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                                        ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B0 S1.00                                          ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                   ; map heated bed to heater 0
      M143 H0 S120                                              ; set temperature limit for heater 0 to 120C
      M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin 121.temp0
      M950 H1 C"121.out0" T1                                    ; create nozzle heater output on 121.out0 and map it to sensor 1
      M307 H1 B0 S1.00                                          ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S300                                              ; set temperature limit for heater 1 to 300C
      M950 F0 C"121.out1" Q500                                  ; create fan 0 on pin 121.out1 and set its frequency
      M106 P0 C"Parts" S0 H-1                                   ; set fan 0 name and value. Thermostatic control is turned off
      M950 F1 C"121.out2" Q500                                  ; create fan 1 on pin 121.out2 and set its frequency
      M106 P1 C"Hotend" S1 H1 T45                               ; set fan 1 name and value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                                          ; define tool 0
      G10 P0 X0 Y0 Z0                                           ; set tool 0 axis offsets
      G10 P0 R0 S0                                              ; set initial tool 0 active and standby temperatures to 0C
      ; Custom settings
      M950 F0 C"out1" Q500                                      ; create fan 0 (parts) on pin out1 and set its frequency
      M376 H5                                                   ; taper bed compensation
      ;M572 D0 S0.05                                            ; pressure advance
      M207 S1.5 F6000	R0 Z0.03                                  ; firmware retraction
      M593 F23                                                  ; set dynamic acceleration
      M671 X0:280 Y0:0 ;S0.75		                                ; define the two Z leadscrew test-positions and max correction of 0.75
      G10 P0 S0 R0                                              ; set T0 heater off
      M150 R0 U0 B0 P5 S8 F0                                    ; shut off neopixel
      if !exists(global.RunDaemon)
       global RunDaemon=true ; create variable for use in daemon.g
      else
       set global.RunDaemon=true ; reset variable for use in daemon.g
      ;M308 S10 Y"mcu-temp" P"121.dummy" A"1LC MCU"
      ;M307 S11 Y"drivers" P"121.dummy" A"1LC Stepper"
      M575 P1 S1 B57600                                         ; enable support for PanelDue
      M501                                                      ; load saved parameters from non-volatile memory
      M911 S23 R24 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"        ; set voltage thresholds and actions to run on power loss
      M572 D0 S0.025                                            ; Pressure Advance
      T0                                                        ; select first tool
        Is there anything that leads up to this? During a print?
        Do you get any errors in the console?
        Can you get an M122 when it's stopped working?
        Is this new with beta 7?
        Stephen6309undefined 1 Reply Last reply Reply Quote 0
          Stephen6309 @Phaedrux
          @phaedrux M122 posted (first one) above and it's beta7. No errors in the console.
          Stephen6309undefined 2 Replies Last reply Reply Quote 0
            Stephen6309 @Stephen6309
            @Phaedrux I noticed dc42 has released a 3.4.0beta+5 for the Mini and beta+4 for the 1LC, have installed them. Now to see if it happens again. The mini is in standalone mode.
            Just remembered: the Y axis would lose some steps during the prior prints. I increase the Y current to 1100, which seemed to work. The Y axis is heavy. The bed is 1/4" mic6 and on a 2020 frame, 3/6" aluminum plate to the mgn12.
              Printing again. Temp on X stepper top is 45.7C Y has 39.2C . Print is farther along than the failed one.
                Stephen6309
                Now on beta7+7. Printing fine for the last four hours. Y driver 37C.
                • DCundefined DC referenced this topic
