    Duet WiFi Expansion Board. PMW Control of 80W Laser Module
    Laser Cutters
    • AllSiriusundefined
      AllSirius
      I've heard very good feedbacks about this laser module and eventually decided to give it a try .
      AliExpress 80w LAser
      In Duet wiki is saying -
      Note: if your system includes either a DueX expansion board or an expansion Breakout Board, then that board already includes this circuitry.
      So I'm attaching the +12v and ground of the laser to Duet 12v power supply
      And PWM to PWM7 on Expansion board .
      When the machine is Laser Mode (m452)
      • the laser is ON from the start. if I unplug the PWM - it's doesn't work.
        If the ground cable is also connected to Expansion PWM7 ground - nothing happening...
      ; Configuration file for Duet WiFi (firmware version 3.3)
      G90                                           ; send absolute coordinates...
      M83                                           ; ...but relative extruder moves
      M550 P"M1"                                    ; set printer name
      M669 ;K1                                      ;Set Cartesian mode
      ;M453         			 ; CNC Mode
      M452 C"exp.heater7"  F250         ; Enable Laser mode, on exp.heater7, with max intensity being 255, and a PWM frequency of 200
      M551 P"*****"                              ; set password
      M552 S1                                       ; enable network
      M586 P0 S1                                    ; enable HTTP
      M586 P1 S0                                    ; disable FTP
      M586 P2 S0                                    ; disable Telnet
      M569 P0 S0                                    ; physical drive 0 goes forwards
      M569 P1 S1                                    ; physical drive 1 goes forwards
      M569 P2 S1                                    ; physical drive 2 goes forwards
      M569 P3 S1                                    ; physical drive 3 goes forwards
      M569 P4 R-1                                    ; physical drive 4 goes forwards
      ;------------------Y MOTOR-------------------------------------------------------------
      M569 P6 R1 T2.5:2.5:5:5 S1
      M569 P7 R1 T2.5:2.5:5:5 S1  ; driver 6,7 direction is backwards and requires an active high enable, 5us minimum step pulse, 2.5us minimum step interval, 5us DIR setup, and 7.5us hold time
      ;-----------------Z MOTOR--------------------------------------------------------------
      M569 P5 R1 T2.5:2.5:5:5 S1 ; driver 5 direction is backwards and requires an active high enable, 5us minimum step pulse, 2.5us minimum step interval, 5us DIR setup, and 7.5us hold time
      ;-----------------EXTRUDER 0 MOTOR-----------------------------------------------------
      ;M569 P9 S0 R1 T5:2.5:5:7.5                        ; driver 9 direction is backwards and requires an active high enable, 5us minimum step pulse, 2.5us minimum step interval, 5us DIR setup, and 7.5us hold time
      M584 X0 Y6:7 Z5 U1 E3				                   ; set drive mapping to external drivers
      M350 X128 U128
      M92 X640.00 Y171.00 Z5050.00 U640 E400.00
      ;M92 X80.00 Y171.00 Z5050.00 U80 E400.00               ; set steps per mm
      M566 X2000.00 Y1300.00 U4000 Z60.00 E800.00          ; set maximum instantaneous speed changes (mm/min)
      M203 X4000.00 Y4000.00 U21000 Z300.00 E1000.00          ; set maximum speeds (mm/min)
      M201 X600.00 Y600.00 U4500 Z80.00 E900             ; set accelerations (mm/s^2)
      M906 X1000 Y1200 Z600 U1200 E760                          ; set motor currents (mA) and motor idle factor in per cent
      M208 X0 Y0 U0 Z-30 S1                             ; set axis minima
      M208 X1019.5 Y790 U800 Z550 S0                       ; set axis maxima
      M574 X2 S1 P"!xstop"                           ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
      M574 Y1 S1 P"!ystop"                           ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      M574 Z1 S1 P"!zstop"                           ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
      M574 U1 S1 P"!e1stop"                          ; configure switch-type (e.g. microswitch) endstop for low end on U via pin zstop
      M558 P0 H5 F120 T6000                         ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:990 Y45:700 S60                      ; define mesh grid
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138
      M950 H1 C"e0heat" T1                                                    ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                                                        ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                             ; set temperature limit for heater 1 to 280C
      M950 F0 C"fan0" Q100                                  ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S1 R1 L15 H-1                                 ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"Fan1" Q3300                                 ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 L1 X1 B0.1 H1 T45                          ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"fan2" Q500                                  ; create fan 0 on pin fan0 and set its frequency
      M106 P2 S1 R1 L255 H1
      ''' Create a tool that uses the low end (X) carriage'''
      ;;M563 P0 S"Spindle" F0 ;R0                                  ; define tool 0
      G10 P0 X0 Y0 Z0 S0 R0                                      ; set tool 0 axis offsets
                 ; Configure Tool 0 as the CNC Spindle
      M950 R0 C"e1heat" Q2000 L0:12000	 ; Create spindle index 0 with
                                               ; inverted PWM output on E0 heater pin
                                               ; and spindle speed of 12000 rpm at maximum PWM
      M563 P0 R0 S"Spindle"            ; Create Tool 0 with Spindle 0 and call it Spindle
      G10 P0 X0 Y0 Z0 S0 R0                 ; Set Tool 0 axis offsets
      M568 P0 F0			 ; Set Tool 0 to default RPM of 0
      T0				 ; Select Tool 0
      ''' Create a tool that uses the high end (U) carriage'''
      M563 P1 S"Extruder" D0 H1 X3 F2                       ; define tool 0
      ;G10 P1 Y-7.4 U-33.5 Z-17
      G10 P1 Y7.5 Z-17                              ; set tool 0 axis offsets
      G10 P1 R0 S0                                          ; set initial tool 0 active and standby temperatures to 0C
      M575 P1 B57600 S1
        dc42 administrators @AllSirius
        @allsirius don't use "exp.heater7" in that command, use "duex.pwm5". Pin "exp.heater7" refers to the signal on the expansion bus, which is inverted because it is active low.
        AllSiriusundefined 1 Reply Last reply Reply Quote 0
          AllSirius @dc42
          @dc42 Thank you for quick replay !
          I guess I wasn't clear enough about my hardware setup:
          I'm using this port on Duet Expansion Breakout Board
          And after I used M452 C"duex.pwm5" F250 command in my Config.g the laser is acting the same. Full power from the start and the fans on it are always on from the V+ and ground form my power supply , even I'm unplugging the PWM from the board.
          So I think I'll need to power it from the third free Fan port on my Duet WiFi to avoid the spinning the Laser fans while it's not in work.
            @allsirius do not try to power the laser from a fan or heater port. If you that then you will probably damage the laser control module, the Duet port that it is connected to, or both.
            Please provide a link to the documentation for that laser.
            If you have a multimeter, please try removing the M452 line from config.g and disconnect the laser, then start the Duet and measure the voltage between the PWM output and ground. It should be 0V.
              AllSirius @dc42
              @dc42 Here is all what I've got about the laser ..
              Laser Aliexpress link.....
              hurzhurzundefined 1 Reply Last reply Reply Quote 0
              • hurzhurzundefined
                hurzhurz @AllSirius
                @allsirius I'm using more or less the same laser module, probably just another form factor: LaserTree LT-80W-LE-Mini
                I first used it with this circuit: https://photos.app.goo.gl/i8Mxxm5eNJhgfwycA
                But now I have switched to the one from the wiki.
                What is missing in the wiki is the info that this circuit needs a inverted signal.
                And according to the wiki page about the breakout board, this is true there as well.
                The example to control a servo is: M950 S0 C"!exp.heater7"
                So, you probably have to use it like this: M452 C"!exp.heater7" F250
                And to control the fan you have to cut the +12V supply to the module.
                As dc42 said, you can't use heater and fan outputs. If i recall correctly, they switch the negative side (GND).
                So you probably would need a separate relay or so to do this.
