Ex0 thermistor trouble
I have installed my duet wifi and most of it works well now. Motors, endstops, z-probing all works as supposed. The only issue I have is the Ex0 thermistor input on the board.
While the bed thermistor worked from the start, the Ex0 always shows 2000C.
Here is what I tried:
- I connected the thermistor directly to the cable coming from the board (not through the smart effector plug) –> still 2000C
- Plugged the Ex0 thermistor in the bed thermistor plug on the board --> works and shows correct temps
- Plugged the bed thermistor in the Ex0 plug on the board --> doesnt works and shows 2000C
- I defined Tool1 and added the added the 2nd thermistor like this:
M143 S260 ; Set maximum heater temperature to 260C
M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
M305 P0 T100000 B4138 C0 R4700 ; Bed Set thermistor + ADC parameters for heater 0
M305 P1 T10000 B3988 C0 R4700 ; Ex0 Set thermistor + ADC parameters for heater 1
M305 P2 T10000 B3988 C0 R4700 ; Ex1
M563 P0 D0 H1 ; Define tool 0
M563 P1 D1 H2 ; Tool 1
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0Cwhich also shows –>2000C
Im using Firmware version 1.19.2 and the config from rff configurator. I have the feeling im missing something in the firmware.
Ill apriciate any help or suggestions
Cheers -
your M305 lines for the extruder Thermistors are wrong the T Params Should be T100000 note 5 zero's you only have 4 in yours?
Aha!
I thought all the Epcos thermistor are similar, so I used the values from the specific epcos from the wiki.
Works now, thanks!
