    Wiring inductive endstops on the Duet 3
    • Jrowundefined
      Jrow
      I'm constructing a machine, that called for using the LJ8A3-2-Z/AX inductive sensor as an end stop. The sensor is rated for voltages of 6-36v, which I'm assuming I can safely get off any voltage out rail, via my power supply. However, I noticed that in the doc found here about wiring a Duet 3, endstop inputs can only tolerate 30v. I was intending to run the board at 32v, and believed this to be safe. What are the consequences / risks associated with running endstops at >30v.
      • A Former User?
        A Former User
        This post is deleted!
