    Writing text and expressions to SD Card
    Gcode meta commands
    • audryhomeundefined
      audryhome
      I want to store some data on SD Card, for instance remember the number of prints, and some specific data gathered during each print, and some macros that automate my printer.
      M28 and M29 are fine for writing macros, but since I can use expressions and meta commands, I didn't found any way to expand an expression in a macro, for instance G1 Z{global.last_Z} is not expanded.
      I probably missed some point, since I am not a Gcode expert, but I am thinking about a M29.1 code that would simply express as
      M29.1 {"var.storedvar ="^var.actualvar^" ; recall last counter"} that would simply expand the above and store it. as
      var.storedvar = 42 ; recall last counter
      This would be similar to an M118 with output redirected to opened SDCard with M28.
      Is this possible ?
      Did I miss something in RRF 3.3?
      Many thanks to the community
      • o_lampeundefined
        o_lampe @audryhome
        @audryhome
        You can use the echo command for this.
        audryhomeundefined 1 Reply Last reply Reply Quote 0
          audryhome @o_lampe
          @o_lampe Many thanks, as always the evidence is just in front of your eye!
