Duet 2 Ethernet WC 3.3.0 crashes, have to reset to reconnect
I have been having this issue randomly and assumed it was due to using Octoprint but have disconnected the USB cable and it has happened again.
Not sure how to configure logging so if someone can point me to that doc first it would probably be helpful. I do not have an LCD. I can not say for sure if this is the entire DWC or just the network module as I noticed it when idle or after print has been removed and I go to start the next (same print job over and over)
Wonder if moving the bed is causing the Y stepper to back feed shutting something down? I do not always manually gab the bed and move it, but was never an issue with the old Rambo board. I do know that I did move it before the last failure.
Thanks!PS. Network status light still flashing when DWC is reachable. Can not recall if it was pingable, but I think it was.
Can you share the results of M122 when it's connected and use USB terminal to get another M122 when it's not able to connect?
@phaedrux What is the name of the Terminal program for usb connection. I have it someplace as I used it when I was setting this up but don't recall the name.
Output when working
I did not try a new network cable but will also eliminate that next time it fails.1/21/2022, 2:45:24 PM M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet Ethernet 1.02 or later Board ID: 0JD0M-9P6B2-NJ4S8-6J1F2-3S46M-KU66M Used output buffers: 1 of 24 (11 max) === RTOS === Static ram: 23876 Dynamic ram: 70772 of which 0 recycled Never used RAM 19768, free system stack 188 words Tasks: NETWORK(ready,27.9%,233) HEAT(delaying,0.0%,336) Move(notifyWait,0.1%,319) MAIN(running,70.3%,441) IDLE(ready,1.7%,29), total 100.0% Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:00:52 ago, cause: software Last software reset at 2022-01-21 14:44, reason: User, GCodes spinning, available RAM 16880, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Step timer max interval 0 MCU temperature: min 38.1, current 38.9, max 39.2 Supply voltage: min 24.2, current 24.3, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Driver 0: position 0, standstill, SG min/max not available Driver 1: position 0, standstill, SG min/max not available Driver 2: position 0, standstill, SG min/max not available Driver 3: position 0, standstill, SG min/max not available Driver 4: position 0, standstill, SG min/max not available Driver 5: position 0 Driver 6: position 0 Driver 7: position 0 Driver 8: position 0 Driver 9: position 0 Driver 10: position 0 Driver 11: position 0 Date/time: 2022-01-21 14:45:23 Cache data hit count 1979751074 Slowest loop: 5.32ms; fastest: 0.17ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 3.3ms, write time 0.0ms, max retries 0 === Move === DMs created 83, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP is ready with "M122 " in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 83.42ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 Interface state active, link 100Mbps full duplex
YAT for yet another terminal
Also try pinging it if it stops responding so we can see if the IP address is still responding or not.
Another option may be to replace the SD card.
How are you using octoprint?
@phaedrux said in Duet 2 Ethernet WC 3.3.0 crashes, have to reset to reconnect:
I was using Octoprint via usb which did continue to work when the WC was not responding. Thinking it was octoprint, I stopped using it. I can try to connect via Octoprint next time the WC fails and if that does not work go straight from a laptop with YAT. Also after last print finished move the bed as I would normally do if need be and had no failure.
@airscapes 2 print jobs in, make a change restarted the board and would not connect via network. Plugged in the pi and Octoprint connected on the first try and this is the output of M122
Sorry forgot to ping it, but did replace the cable before this as when I first connected it said it failed with network error and retied..Send: M122 Recv: === Diagnostics === Recv: RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet Ethernet 1.02 or later Recv: Board ID: 0JD0M-9P6B2-NJ4S8-6J1F2-3S46M-KU66M Recv: Used output buffers: 1 of 24 (21 max) Recv: === RTOS === Recv: Static ram: 23876 Recv: Dynamic ram: 70804 of which 0 recycled Recv: Never used RAM 16880, free system stack 134 words Recv: Tasks: NETWORK(ready,29.1%,233) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,313) MAIN(running,70.7%,441) IDLE(ready,0.2%,29), total 100.0% Recv: Owned mutexes: USB(MAIN) Recv: === Platform === Recv: Last reset 00:09:13 ago, cause: software Recv: Last software reset time unknown, reason: User, GCodes spinning, available RAM 19768, slot 0 Recv: Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Recv: Error status: 0x00 Recv: Step timer max interval 0 Recv: MCU temperature: min 45.5, current 46.3, max 47.5 Recv: Supply voltage: min 23.7, current 23.9, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes Recv: Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/30/30, gc cycles 0 Recv: Driver 0: position 0, standstill, SG min/max 12/348 Recv: Driver 1: position 10586, standstill, SG min/max 0/333 Recv: Driver 2: position 14109, standstill, SG min/max 0/108 Recv: Driver 3: position 0, standstill, SG min/max 0/212 Recv: Driver 4: position 0, standstill, SG min/max not available Recv: Driver 5: position 0 Recv: Driver 6: position 0 Recv: Driver 7: position 0 Recv: Driver 8: position 0 Recv: Driver 9: position 0 Recv: Driver 10: position 0 Recv: Driver 11: position 0 Recv: Date/time: 2022-01-22 18:09:50 Recv: Cache data hit count 4294967295 Recv: Slowest loop: 47.47ms; fastest: 0.09ms Recv: I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 Recv: === Storage === Recv: Free file entries: 10 Recv: SD card 0 detected, interface speed: 20.0MBytes/sec Recv: SD card longest read time 3.9ms, write time 0.0ms, max retries 0 Recv: === Move === Recv: DMs created 83, maxWait 84260ms, bed compensation in use: none, comp offset 0.000 Recv: === MainDDARing === Recv: Scheduled moves 129, completed moves 129, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 Recv: === AuxDDARing === Recv: Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 Recv: === Heat === Recv: Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Recv: Heater 0 is on, I-accum = 0.6 Recv: Heater 1 is on, I-accum = 0.4 Recv: === GCodes === Recv: Segments left: 0 Recv: Movement lock held by null Recv: HTTP is idle in state(s) 0 Recv: Telnet is idle in state(s) 0 Recv: File is idle in state(s) 0 Recv: USB is ready with "M122" in state(s) 0 Recv: Aux is idle in state(s) 0 Recv: Trigger is idle in state(s) 0 Recv: Queue is idle in state(s) 0 Recv: LCD is idle in state(s) 0 Recv: Daemon is idle in state(s) 0 Recv: Autopause is idle in state(s) 0 Recv: Code queue is empty. Recv: === Network === Recv: Slowest loop: 48.68ms; fastest: 0.02ms Recv: Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Recv: HTTP sessions: 0 of 8 Recv: Interface state active, link 100Mbps full duplex Recv: ok [...]
@airscapes Opps! The thermostatic controlled fan was not running, seems like a connection issue or a cracked board. Had the X endstop not working the other week, reseated the connector and that has not happened but the connector was not loose and it was not a connector I replaced.. Will update with ping status if this happens again.
@airscapes pint job done, did not look at the dang gui first, went and pulled the bed out on the Y axis to remove the print. Went to pc and was disconnected. Could not ping
oot@ [/root] # ping 192.168.1.245
PING 192.168.1.245 (192.168.1.245) 56(84) bytes of data.
From 192.168.1.101 icmp_seq=1 Destination Host Unreachable
From 192.168.1.101 icmp_seq=2 Destination Host Unreachable
From 192.168.1.101 icmp_seq=3 Destination Host Unreachable
From 192.168.1.101 icmp_seq=4 Destination Host Unreachable
From 192.168.1.101 icmp_seq=5 Destination Host Unreachable
From 192.168.1.101 icmp_seq=6 Destination Host Unreachable
From 192.168.1.101 icmp_seq=7 Destination Host Unreachable
From 192.168.1.101 icmp_seq=8 Destination Host UnreachableStill have flashing green light and orange link light.
Had to push da reset button.. again. -
@Phaedrux
Just found one thing that "Might" be causing this issue but not positive. I had the network set to DHCP and I also had forgotten to add a Fixed entry for the host in the router. I am doubtful this is it, because I would not think the gui would return me a message that a network error had occurred if it just get a new IP and did not look when it was offline. I now have the Duet set to a fixed IP and the router set so that mac always get that same IP or should I say, so it does not give that IP to anyone else.
Is there a way to add additional logging and is there a CLI to the OS from the USB connections to see if the Web interface is still running should I get another failure??BTW I did verify that disconnecting the network and reconnecting works just fine.. i.e. remove the cable wait a few moment, plug it back in, gui still works as it should. So other than an IP address no longer being on the interface or the IP I was expecting.. I don't think this is related to anything external in the network.
Thanks! -
If you get a disconnection again use the USB terminal again as you did when you got the M122 report but this time send M552 and see what IP address it has.
@phaedrux Yep, will do! Have not used the printer but have several things to print today. Seems like my configuation failures would very likely cause the symptoms.. The nic was not dead, link and trafic lights still working so no IP or different IP makes perfect sense.
@Phaedrux So much for that.. just lost connection after canceling a print job and homing Z. Ran the 552 and 122 again, also started the job from the usb connection without resetting the board if there is something else I can do to try and figure this out..
Recv: Network is enabled, configured IP address: 192.168.1.245, actual IP address: 192.168.1.245
Recv: ok
From pc to printer
Pinging 192.168.1.245 with 32 bytes of data:
Reply from 192.168.1.161: Destination host unreachable.Ping statistics for 192.168.1.245:
Packets: Sent = 1, Received = 1, Lost = 0 (0% loss),
Control-CHere is m122 again
Send: M122
Recv: Used output buffers: 1 of 24 (22 max)
Recv: === RTOS ===
Recv: Dynamic ram: 70804 of which 320 recycled
Recv: Never used RAM 16560, free system stack 112 words
Recv: Tasks: NETWORK(ready,762.2%,225) HEAT(delaying,0.9%,330) Move(notifyWait,3.5%,313) MAIN(running,302.5%,420) IDLE(ready,0.2%,29), total 1069.2%
Recv: Last reset 03:56:56 ago, cause: power up
Recv: Last software reset at 2022-01-23 12:09, reason: User, GCodes spinning, available RAM 16560, slot 2
Recv: MCU temperature: min 20.4, current 54.9, max 59.3
Recv: Supply voltage: min 23.7, current 23.8, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
Recv: Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/120/120, gc cycles 0
Recv: Driver 0: position 0, standstill, SG min/max 0/355
Recv: Driver 1: position 178, standstill, SG min/max 0/360
Recv: Driver 2: position 213533, standstill, SG min/max 0/1023
Recv: Driver 3: position 0, standstill, SG min/max 0/1023
Recv: Date/time: 2022-01-25 11:36:51
Recv: Slowest loop: 90.23ms; fastest: 0.09ms
Recv: SD card longest read time 4.0ms, write time 40.0ms, max retries 0
Recv: === Move ===
Recv: DMs created 83, maxWait 9607499ms, bed compensation in use: none, comp offset 0.000
Recv: Scheduled moves 1, completed moves 1, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1
Recv: === Heat ===
Recv: Heater 0 is on, I-accum = 0.8
Recv: Heater 1 is on, I-accum = 0.3
Recv: Slowest loop: 193.31ms; fastest: 0.02ms
Recv: ok -
Thanks.
When and where did you purchase your Duet?
@phaedrux MatterHackers.com Nov 20 2021
Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
@phaedrux Ok, thanks! Will post how it goes. Email sent
@airscapes said in Duet 2 Ethernet WC 3.3.0 crashes, have to reset to reconnect:
The return has been started, still waiting to hear details from Matterhackers about what to do next but they did email me and said I would be contacted.
I have been using the printer today with no issues until I smacked a print with the spatula to remove it, when I returned to the desk the network connection was gone. Guess the vibrations is all it took as I did not move any cables or touch the board enclosure.
@Phaedrux Return initiated and shipping shortly!!
This has been one of the best trouble shooting and return process I have ever had. Top notch and thanks you very much! -
@Phaedrux
Wow this is not good.. Replacement board installed on the weekend. Did my first print today. PETG so no heat in the enclosure, 35 minute print job, finished, when into the other room pulled the bed out manually (been doing that since I got it as the manufacture said it is fine to do. removed the print, returned to desk and I am now disconnected. Checked m552 still had an IP, network module still flashing lights. connected to usb with octoprint, head bead still on as it should have been as I did not turn it off at the end of the job. Hit reset button, and after boot was back on the network. So what is the next step. Guess I will email Matterhackers and let them know still have the same problem?? Is there any more trouble shooting we can do. can not recreate problem on demand. -
It's pretty unlikely that the new board has an issue with ethernet as well. I think it's more likely that the issue is on the network hardware side. The Duet appears to still have an address and seeing activity.
What network hardware is between your PC and the Duet? Do you have any means of testing something alternative?
