    Z homing question
    • medicusdkfzundefined
      medicusdkfz
      Is there a difference between
      #1:
      G31 K1 P500 X0 Y0 Z0
      G30 K1 -> above the probing pin without G92 Z0
      and #2:
      G30 K1 Z-99999 -> above the probing pin
      G92 Z0
      The question is: Is G92 Z0 necessary for homing z?
      • fcwiltundefined
        fcwilt @medicusdkfz
        @medicusdkfz said in Z homing question:
        #1:
        and #2:
        G92 Z0
        G92 Z0 sets the current logical Z position to 0 thus overriding the result of the G30.
        Questions:
        • do you actually have a G31 in your homing code?
        • do you actually have the Z-99999 in your homing code.
          medicusdkfz
          ; homez.g
          ; called to home the Z axis
          ; do nothing if XY is not homed yet
          if !move.axes[0].homed || !move.axes[1].homed
              echo "XY are not homed yet. Aborting!"
              abort
          ;end if
          M98 P"/macros/magprobe_get_status.g"
          if global.magprobe_status = "docked"
          	M98 P"/macros/goto_z_switch.g"		    ; Goes over the Z-Switch PIN !!!! CHECK COORDINATES CAREFULLY !!!!
          	G30 K1 Z-99999						    ; Probe the Z pin at the back
          	G90
          	G1 Z10 F9000
          elif global.magprobe_status = "attached"
          	M98 P"/macros/magprobe_dock.g"
          	G90
          	G1 Z10 F9000
          else
          	echo "Magprobe-status not detected. Aborting!"
          	abort
          This is my homez.g... I mentioned G31 for a better understanding. I guess, the trigger point of the probe will be set to the z-parameter in G31. In my case to 0 or to an offset...
