    MFM no data received issue
    Filament Monitor
    • Dakotaundefined
      Dakota
      So my customer’s printer is having an issue with their magnetic filament sensor that they’re less than pleased with and I’m unable to provide solutions for them. The sensor has been more of a hinderance to them than help and it’s frustrating on my end since I’ve had decent success with an indirect laser sensor for over a year now.
      The issue is that while printing the sensor is flashing red and green as it should and the m591 reports good measurements. As soon as I enable filament sensing it errors out saying no data retrieved, which makes no since when I can watch the sensor working in the object model section. It seems I’m not the only one having issues with the sensor so until I can see the issues have been sorted out on the forums I just need to keep it shut off from doing it’s job…
      Here are the machine status reports:
      M591 D0
      Duet3D rotating magnet filament monitor v3 on pin io6.in, disabled, sensitivity 24.50mm/rev, allow 20% to 220%, check all moves every 5.0mm, version 3, mag 129 agc 90, measured sensitivity 25.64mm/rev, min 95% max 105% over 2499.2mm
      M122
      RepRapFirmware for Duet 3 Mini 5+ version 3.4.0beta6 (2021-11-06 11:39:32) running on Duet 3 Mini5plus WiFi (standalone mode)
      Board ID: Q9LL5-B296U-D65J0-40KM0-N503Z-Z51M7
      Used output buffers: 3 of 40 (24 max)
      Static ram: 103876
      Dynamic ram: 113484 of which 28 recycled
      Never used RAM 20652, free system stack 118 words
      Tasks: NETWORK(ready,6.4%,234) ACCEL(notifyWait,0.0%,346) HEAT(notifyWait,0.5%,340) Move(notifyWait,19.3%,265) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,358) CanClock(delaying,0.3%,331) TMC(notifyWait,23.2%,71) MAIN(running,33.5%,414) IDLE(ready,0.6%,29) AIN(delaying,16.2%,264), total 100.0%
      Owned mutexes:
      Last reset 21:50:27 ago, cause: power up
      Last software reset at 2021-12-22 16:54, reason: User, GCodes spinning, available RAM 20972, slot 0
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x00
      MCU revision 3, ADC conversions started 78627634, completed 78627633, timed out 0, errs 0
      Step timer max interval 1476
      MCU temperature: min 27.4, current 57.3, max 58.4
      Supply voltage: min 23.8, current 23.9, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/5, heap memory allocated/used/recyclable 2048/328/248, gc cycles 4
      Driver 0: pos 46292, standstill, SG min 0, read errors 0, write errors 0, ifcnt 41, reads 4106, writes 41, timeouts 0, DMA errors 0
      Driver 1: pos -1819, standstill, SG min 0, read errors 0, write errors 0, ifcnt 41, reads 4106, writes 41, timeouts 0, DMA errors 0
      Driver 2: pos 46131, standstill, SG min 0, read errors 0, write errors 0, ifcnt 41, reads 4106, writes 41, timeouts 0, DMA errors 0
      Driver 3: pos 0, ok, SG min 0, read errors 0, write errors 0, ifcnt 103, reads 4044, writes 103, timeouts 0, DMA errors 0
      Driver 4: pos 0, ok, SG min 0, read errors 0, write errors 0, ifcnt 103, reads 4044, writes 103, timeouts 0, DMA errors 0
      Driver 5: pos 0, ok, SG min 0, read errors 0, write errors 0, ifcnt 38, reads 4109, writes 38, timeouts 0, DMA errors 0
      Driver 6: pos 0, standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 4138, writes 9, timeouts 0, DMA errors 0
      Date/time: 2022-01-25 12:03:55
      Slowest loop: 999.36ms; fastest: 0.06ms
      === Storage ===
      Free file entries: 9
      SD card longest read time 4.9ms, write time 142.4ms, max retries 0
      DMs created 83, segments created 34, maxWait 41482150ms, bed compensation in use: mesh, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 236112, completed 236083, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 3], CDDA state 3
      === AuxDDARing ===
      Bed heaters 0 -1, chamber heaters -1 -1, ordering errs 0
      Heater 0 is on, I-accum = 0.3
      Heater 1 is on, I-accum = 0.8
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is doing "G1 X254.676 Y318.277 E21.66278" in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty
      === Filament sensors ===
      Extruder 0: pos 205.31, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
      === CAN ===
      Messages queued 707809, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 16), ts 393137/0/0
      Tx timeouts 0,167,393136,0,0,314502 last cancelled message type 30 dest 127
      === Network ===
      Slowest loop: 217.36ms; fastest: 0.00ms
      HTTP sessions: 2 of 8
      • WiFi -
        Network state is active
        WiFi firmware version 1.26
        WiFi MAC address f0:08:d1:03:81:17
        WiFi Vcc 3.35, reset reason Power up
        WiFi flash size 2097152, free heap 21384
        WiFi IP address 10.18.86.16
        WiFi signal strength -61dBm, mode 802.11n, reconnections 0, sleep mode modem
        Clock register 00002002
        I believe the sensor should be replaced.
        Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
        Sorry for the inconvenience.
        Dakotaundefined 1 Reply Last reply Reply Quote 0
        • Dakotaundefined
          Dakota @Phaedrux
          @phaedrux
          Ok I’ll contact my reseller. The thing I’m worried of is this is the second sensor I’ve had to buy for them. I’m really hoping third time’s the charm…
