    Method to disable homing during print
    Gcode meta commands
    • Stephen6309undefined
      Stephen6309
      Some have suggested: to check if the state.status is "processing" when homing.
      Problem: It is always "processing" the moment the print is started, so homing never occurs during the print. Which means, you start the print and then get many not homed errors.
      I set a global variable in config.g and checkit in the homing files. Call the enable/disable in the slicer's start gcode and a enabie in the end gcode.
      Note: you will get homing failed errors when homing is disabled in the homing files.
      In config.g:
      if !exists(global.DisableHoming)
       global DisableHoming=false  ;create variable for use in homing
      else
       set global.DisableHoming=false ;reset variable for use in homing
      In the homeing files add at the beginning:
      if global.DisableHoming
       M99
      EnableHoming macro:
      DisableHoming macro:
      set global.DisableHoming=true
      In the slicer's start gcode:
      M98 P"EnableHoming"
      G28                            ; home all axes
      M98 P"DisableHoming"
      Add M98 P"EnableHoming" in the end gocde in the slicer
      deckingmanundefined 1 Reply Last reply Reply Quote 4
      • Phaedruxundefined Phaedrux moved this topic from Using Duet Controllers
      • deckingmanundefined
        deckingman @Stephen6309
        @stephen6309 said in Method to disable homing during print:
        Umm - I have to ask.......a) why would you want to run homing macros during a print? and b) Why would you want to start a print if the machine had not been homed (resulting in error messages)?
        Scratch that - I think I've worked it out - I assume this is for the use case where you run homing macros as part of the slicer start code yes?
        Stephen6309undefined 1 Reply Last reply Reply Quote 0
          Stephen6309 @deckingman
          @deckingman Yes. I don't want to have to remember to manually home before starting a print. Slicers have been doing that as a default in the start gcode, since I started with a Prusa 2 linear kit.
            dc42 administrators @Stephen6309
            @stephen6309 you can test the values of moves.axes[N].homed for each axis number N that matters.
              Stephen6309 @dc42
              @dc42 I already test for not homed in bed.g, since they won't work without homing. Also in mesh.g if it has to make the heightmap.csv.
                @stephen6309 so why not test in start.g too, and home if necessary? Then change the start GCode of the slicer not to home the printer.
                  Stephen6309 @dc42
                  @dc42 I haven't set up a start.g file. But that's a good idea.
                  • modlundefined modl referenced this topic
