    Creality CR6 SE Stepper noise
    • wijkhuisenundefined
      wijkhuisen
      I have a problem with my Duet2 wifi board on my Creality CR6-SE. I have a duet2 wifi on my hypercube and it works fine and is nice and quiet. Because I like the board so much, I also wanted it on my CR6-SE. Now I have it connected but the steppers make a lot of noise, the steppers of the hypercube are much quieter. They also make a hissing sound at idle. I don't hear this with the hypercube either. When I send M84 everything is silent. The steppers are connected correctly and everything is going in the right direction. The CR6-SE is on 24V and the hypercube is on 12V.
      M569 P0 S0 ; physical drive 0 goes backwards
      M569 P3 S0 ; physical drive 3 goes backwards
      M350 E128 I0 ; configure microstepping without interpolation
      M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E741.00 ; set steps per mm
      M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
        Different steppers, different voltage, different noise.
        You can check this wiki article and see if there are some things you can play with to improve it. There is no simple fix.
        https://duet3d.dozuki.com/Wiki/Tuning_Stepper_Motor_Drivers
