How does the trigger heights in bed.g affect the height map?
I'm just wondering if the offsets set in bed.g are used at all in the heightmap, if there is some sort of interpolation going on.
According to the instructions for calibrating a Delta printer, the Z-offset used in the config.g file is the trigger height at 0,0 - and the heights in bed.g are relative to that trigger height.
However, if there is a spot on my bed that has a larger trigger height, is this compensated for when doing the mesh grid?
No it isn't
