Shorted fan 0 wires. Now fan won't stop.
I was doing some wiring of my part fan (fan0) and I forgot to turn off the printer. I shorted the two wires together and the board rebooted. Now that I have it all rewired, the fan is on 100% all the time (even when not printing). Does that seem like how it would fail if I damaged my board?
If so, I assume it is possible to use a different fan port and somehow map that to my part fan? -
@erice555 Yep, that is exactly what happened. Remapped it to fan 8 (duex board) and all is well.
Yes it's likely the mosfet was blown and failed in the on state.
the mosfets can be replaced if you're handy with an iron.
https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#Section_Fan_mosfet
