    COREXZ conversion tuning
    1
    231
    • danzaywerundefined
      danzaywer
      i just finished converting my AM8BLV to COREXZ (SWITCHWIRE adapt) and it seems to work fine.
      However, I have some doubts about some conversions to do with the new kinematics:
      with the Cartesian in the homing I raised the Z axis by 5mm still not homed to ensure that the noozle did not hit the plane
      G1 H2 Z5
      now this command move the z motor individually and then the carriage moves diagonally right-down. i solved by inserting
      G1 H2 X5 Z-5
      is it the right solution or is it possible to use something cleaner?
      I encountered another problem with the bi MBL procedure, with the Cartesian probe the 4 corners of bed with the bltouch and firmware return to me the number of turns to be carried out on the screws to level the surface, now with the new kinematics I get the message that
      M671 parameters do not apply to CoreXZ kinematics
      and
      Error: This kinematics does not support auto-calibration
      in bed.g I have
      	M401
      	M671 X23.7:232.7:232.7:23.7 Y219:219:10:10 P0.35
      	G30 P0 X23.7 Y219 Z-99999 		; probe near an adjusting screw
      	G30 P1 X232.7 Y219 Z-99999 		; probe near an adjusting screw
      	G30 P2 X232,7 Y10 Z-99999 		; probe near an adjusting screw
      	G30 P3 X23.7 Y10 Z-99999 S4		; probe near an adjusting screw
      	M400
      	M402
      	G1 X{var.xCenter-sensors.probes[0].offsets[0]} Y{var.yCenter-sensors.probes[0].offsets[1]}  F6000
      	G30
      is not possible to use manual bed leveling?
      in config.g I have
      M584 X2 Y1 Z0 E3:3:3:3:3:3 U4 V8 W3 P5									; corexz
      M669 K2 X1:0:1:0:0:0 Y0:1:0:0:0:0 Z1:0:-1:0:0:0
      where U V and W are ERCF axes, is correct or I can simply put
      M669 K2 X1:0:1 Y0:1:0 Z1:0:-1
      instead ?
      Thanks in advance
      • danzaywerundefined danzaywer marked this topic as a question
