    Solved Commands to either driver 4 or drive 5 only control driver 4
    Firmware installation
    • seventhwhiskey
      seventhwhiskey last edited by
      I have two tools configured in DSF 3.3.0 running in SBC mode (T1 with driver 4, T2 with driver 5). Commands sent to T1 execute through driver 4 as expected. Commands sent to T2 also execute on driver 4 (not expected). No idea what's happening here, any ideas? config.g below:
      ; Configuration file for Duet 3 (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Tue Feb 01 2022 16:47:18 GMT-0600 (Central Standard Time)
      G90                                                       ; send absolute coordinates...
      M83                                                       ; ...but relative extruder moves
      M550 P"duet3"                                             ; set printer name
      M569 P0.0 S1                                              ; physical drive 0.0 goes forwards
      M569 P0.1 S0                                              ; physical drive 0.1 goes forwards
      M569 P0.2 S1                                              ; physical drive 0.2 goes backwards
      M569 P0.3 S0                                              ; physical drive 0.3 goes forwards
      M569 P0.4 S0                                              ; physical drive 0.4 goes backwards
      M569 P0.5 S1                                              ; physical drive 0.5 goes forwards
      M584 X0.0 Y0.1 Z0.2:0.3 E0.4:0.5                          ; set drive mapping
      M350 X32 Y32 Z32 E64:64 I0                             ; configure microstepping without interpolation
      M92 X160.00 Y160.00 Z800.00 E415.00:415.00         ; set steps per mm
      M566 X900.00 Y900.00 Z180.00 E120.00:120.00        ; set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z6000.00 E1200.00:1200.00  ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E250.00:250.00        ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800E800:800 I30                      ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                   ; Set idle timeout
      M208 X0 Y0 Z0 S1                                          ; set axis minima
      M208 X350 Y350 Z400 S0                                    ; set axis maxima
      M574 X1 S1 P"io0.in"                                      ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in
      M574 Y1 S1 P"io1.in"                                      ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in
      M950 S0 C"io7.out"                                        ; create servo pin 0 for BLTouch
      M280 P0 S60
      M558 P9 C"io7.in" H5 F600 T6000                   		  ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-44 Y-9 Z2.5                                    ; set Z probe trigger value, offset and trigger height
      M557 X50:300 Y50:300 S20                                  ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4092              ; configure sensor 0 as thermistor on pin temp3
      M950 H0 C"out0" T0                                        ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B0 S1.00                                          ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                   ; map heated bed to heater 0
      M143 H0 S80                                               ; set temperature limit for heater 0 to 80C
      M308 S1 P"temp1" Y"thermistor" T100000 B4685 C6.519681e-8 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1                                        ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 B0 S1.00                                          ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                              ; set temperature limit for heater 1 to 280C
      M308 S2 P"temp2" Y"thermistor" T100000 B4685 C6.519681e-8 ; configure sensor 2 as thermistor on pin temp2
      M950 H2 C"out2" T2                                        ; create nozzle heater output on out2 and map it to sensor 2
      M307 H2 B0 S1.00                                          ; disable bang-bang mode for heater  and set PWM limit
      M143 H2 S280                                              ; set temperature limit for heater 2 to 280C
      M950 F0 C"out7" Q500                                      ; create fan 0 on pin out7 and set its frequency
      M106 P0 C"part-cooling" S0.65 H-1                         ; set fan 0 name and value. Thermostatic control is turned off
      M950 F1 C"out8" Q500                                      ; create fan 1 on pin out8 and set its frequency
      M106 P1 C"hotend1" S0.65 H1 T100                          ; set fan 1 name and value. Thermostatic control is turned on
      M950 F2 C"out9" Q500                                      ; create fan 2 on pin out9 and set its frequency
      M106 P2 C"hotend2" S0.65 H2 T100                          ; set fan 2 name and value. Thermostatic control is turned on
      M563 P1 D0.4 H1 F0                                          ; define tool 1
      G10 P1 X-7 Y0 Z0                                          ; set tool 1 axis offsets
      G10 P1 R0 S0                                              ; set initial tool 1 active and standby temperatures to 0C
      M563 P2 D0.5 H2 F0                                          ; define tool 2
      G10 P2 X7 Y0 Z0                                           ; set tool 2 axis offsets
      G10 P2 R0 S0                                              ; set initial tool 2 active and standby temperatures to 0C
      ; Custom settings
      M929 S3                                                   ; enable logging
      M501                                                      ; load saved parameters from non-volatile memory
      M911 S12 R20 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"        ; set voltage thresholds and actions to run on power loss
      o_lampe 1 Reply Last reply Reply Quote 0
      • o_lampe
        o_lampe @seventhwhiskey last edited by
        @seventhwhiskey
        With M563 you shouldn't use the real driver numbers for the extruders, but their logical order as they appear in the M584 drive mapping.
        Tool 0 is D0; Tool1 is D1
        seventhwhiskey 1 Reply Last reply Reply Quote 2
        • seventhwhiskey
          seventhwhiskey @o_lampe last edited by
          @o_lampe Thanks, that was it. D0.4 and D0.5 were both being interpreted as D0; changing to D0 and D1 fixed it.
          • Topic has been marked as a question  dc42 dc42
          • Topic has been marked as solved  dc42 dc42
