    Home without crashing
    • Reefwarriorundefined
      Reefwarrior
      Hi all,
      I don't know if this is in the correct part of the forum, but here goes.
      My homing sequence raises Z, home X, lowers Z; raises Z, home Y, lowers Z; raises Z, home Z, lowers Z. (of course I have set a 'false' 0 location in order to have Z raise....); anyway, this is what happened.
      I stopped a print or something, for whatever reason; and I started a new print. Obviously homeall.g runs; but because Z is too low; it extended the bltouch probe, which caused an error (too low so it was not able to extend the pin all the way); which meant the head came crashing down into the bed - as it was determined to do the probe.
      Is there a way I can prevent this from happening in the future, by means of code in the homeall.g file?
      Any/all help appreciated!
      Tinus
      Stephen6309undefined fcwiltundefined 2 Replies Last reply Reply Quote 0
      • Stephen6309undefined
        Stephen6309 @Reefwarrior
        @reefwarrior I use this right after the G91 in my homing files. It makes sure the nozzle/bltouch is far enough from the bed.
        G1 H2 Z10 F6000         ; lift Z relative to current position
        • fcwiltundefined
          fcwilt @Reefwarrior
          @reefwarrior
          Since homing Z with a probe can led to situations like you describe all of my printers include a Z endstop sensor which allows for unambiguous Z homing. No more Z up, Z down when homing X and Y. Just home Z and leave at a suitable position like Z=10 then home X and home Y. Since the Z position is always known there are no issues with probing with Z too low.
